Gordon2448
Central Coast, California
I have a 3-axle 39ft toyhauler. Has approx 2000 miles (4 trips). I was washing the trailer when i noticed the outside of the right tire on the 3rd axle is almost bald. The inside isnt as bald. I looked at the tire on the other side and it is balding on the inside, outside of the tire is fine. The trailer rides level when hitched to the truck. Is this due to the 3rd axle tires sliding more on the asphalt while turning OR what i think, an axle missalignment??
lawnspecialties
Garner, NC
Gordon2448 wrote: I have a 3-axle 39ft toyhauler. Has approx 2000 miles (4 trips). I was washing the trailer when i noticed the outside of the right tire on the 3rd axle is almost bald. The inside isnt as bald. I looked at the tire on the other side and it is balding on the inside, outside of the tire is fine. The trailer rides level when hitched to the truck. Is this due to the 3rd axle tires sliding more on the asphalt while turning OR what i think, an axle missalignment??
Only 2000 miles, I would bet bad alignment or something bent; especially the way one is on the inside and the other on the outside.
Good luck.
2011 Ford F450 4X4
2011 Cyclone 370C
USMA Dad
Stuart, FL
Sounds like it could be a missalignment issue. Do the front axle tires show any signed of wear? Your center axle serves as a pivot and your front and rear will definitely scuff across the road surface. One thing I read as I was considering a TH was to take turns extremely slow. I watch in amazement the bend and flex in my axles as I make tight turns. I swear the bead is going to give! Our TH is nearly a year old with about 6500-7000 miles of travel and all of the tires seem to wearing evenly.
Don Z.
'11 Dodge 3500 CTD 4x4 DRW
'12 Jayco Recon ZX 39A
oh yeah, and the wife, kids, and dogs!
Diesel is cheaper than beer. Who's gonna stop drinking???
Member of the Masonic group RVTravelingMen
trucker495
Linden, CA
Take it to a big rig alignment shop and they can diagnose the problem. Had a similar problem on the trailer in my signature.(left driverside rear tire wearing on inside)
Happy trails
04 HR ALUMASCAPE 31' TRAVEL TRAILER
05 RAM 3500 4X4 CTD SRW CREW CAB LONGBED
lincster
Mesa Az
That few of miles, something is bent.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
BigDogF250
Ramona, CA
What does your "normal" drive look like? Mine wear excessively on the rear axle but my normal drive is 100 miles of TWISTY roads and I can see the rear tires scrubbing as I turn and they do wear out first on the outsides of the tires (looks like a car with a bad alignment). However they wear evenly on the same axle left/right. I have done measurements myself and had a shop check as well, it's straight.
Given the uneven wear I concur with the others, get it checked out (unless your normal drive is around a Nascar track - you know, all left turns)
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200 pulled by 05 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR and one Goffin Cockatoo
BoonHauler
BoonDocks
your rear axle is mis-aligned. best way to measure is spindle to spindle. whos running gear do you have?.....Dexter, Lippert?.....other?
05 RAM 3500 CTD 4x4 Q/C DRW/NV5600/3.73
Gordon2448
The routes are primarly straight (Salinas to Pismo, Salinas to Lucerne valley). Most of the turning is done on the streets around my home. The frame is "Lippert". And, i am taking it into the shop today.
gpshemi
Lapeer, Michigan
I had to have mine re-aligned. They acutally bend the axles back to in spec. However, while talking to the tech, he said it happens all the time. He's seen them come out of the factory out of spec. Mines been great since the alignment.
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/ bombed 5.9L
18K Pullrite SuperGlide w/super rails
2010 Heartland Cyclone 3612
WFOBansheeboy
Discovery Bay
gpshemi wrote: I had to have mine re-aligned. They acutally bend the axles back to in spec. However, while talking to the tech, he said it happens all the time. He's seen them come out of the factory out of spec. Mines been great since the alignment.
X2^
I have 2trailer right from the factory out align. Take it to the shop have then check it out re-align it and you should be good to go. Keep us posted .
06 F250 6.0L 4X4
FabTech 8" lift W/dirt logic 4.0 Front & 2.5 rear
Rolling on 38X13.5X18
4.56 W/ARB air locker front & rear
Banks Big Hoss Kit with IQ & Banks cool air intake
BPD oil cooler & EGR cooler
04 Sierra 39 5th
My ride 92 Banshee
Wife ride 08 TRX250EX
