RV.Net Open Roads Forum: Tow Vehicles: Retractable Tonneau Covers
Search only in Tow Vehicles
 > Retractable Tonneau Covers
BB_TX
McKinney, Texas
Posted: 08/08/12 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Just traded the '07 F350 for a '12 F350. Had a Pace Edwards Full Metal Jackrabbit on it. After 5 years still looked very good and worked good. Was only just beginning to see some chips in the powder coating.
Now I need a cover for the '12. The '12 is a King Ranch so the bed rail protectors are tan instead of black like the '07 Lariat. Not sure how a black cover will look with the tan rails. But I don't see any color options for any retractable covers except black and, on a very few, silver. Not interested in silver.
Need a retractable cover to retract back over my 5th wheel hitch, and to cover it and lock in place when not towing.
So. Does any one have a black tonneau cover on their King Ranch with tan rails? And how does it look?
dspencer
Missouri
Posted: 08/08/12 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have it but a friend of my neighbors has your truck with the Black Tonneau Cover and tan rails and IMO it looks great. I see him over there from time too time. My neighbor also works at Ford here in Kansas City. I personally think its a very sharp truck but again thats JMHO.
JRS & B
Florida/Michigan
Posted: 08/08/12 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Come on. I have seen one on a red Ford. I had to tell the guy how good it looked. The web sites show then on white, red, blue and silver trucks. Actually, anything but black. I can't think of any reason why tan would be an exception.
BB_TX
McKinney, Texas
Posted: 08/08/12 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Just to be clear. The truck is white and has tan plastic rail covers, typical of the King Ranch. Generally the plastic rail covers are black.
T-10 Parabolic
Western North Carolina
Posted: 08/08/12 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Pace Edwards cover on my King Ranch that has the tan rails and I think it looks great..
Just a heads up,, when you get your hitch adjusted for a level 5er your release handle may be too high for the cover to close, if so tilt the hitch up that will put your handle down, cut two wood wedges and insert them to hold the hitch tilted up.. Had to do that on mine,, just remember to remove before hooking up the 5er!!! T-10
2011 King Ranch, 350 DRW. CC, 8' bed, 4X4 6.7 PSD
2011 34RLTS Jayco Pinnacle
BB_TX
McKinney, Texas
Posted: 08/08/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks T-10 for the info from someone who has already been there. I think I will go with the Pace Edwards again.
As far as the handle, I have the hitch in the lowest holes and it looks like the handle will clear unless it tilts to the passenger side. But I was thinking I would just put a bungee around the handle to the bottom of the hitch to hold the handle down. That way I would not forget something I could not see.
57 Panhead
Central Valley Calif.
Posted: 08/08/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Go for it, it will look great. Love the Pace Edwards covers.
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
JRS & B
Florida/Michigan
Posted: 08/09/12 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I cannot find a comment on what kind of hitch you have. When my handle hit the cover I just sawed off a couple of inches of the handle. That might not be an option for you, but I toss it out for consideration.
BB_TX
McKinney, Texas
Posted: 08/09/12 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I have the Ford factory 5th wheel/gooseneck hitch prep and 5th wheel hitch (a Reese hitch). I have it at the lowest setting. Sitting level the handle is just below the rails. If it tilts to the passenger side it would be just above the rails. So if I keep it level or tilted to the drivers side it will be fine.
Sprinks542
Western Pa.
Posted: 08/09/12 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
If you're worried about the tan and black not matching, change the bed rail covers to black. easy to do. One of mine started to warp some so dealer took a hot air gun to the back side and straighten it until my new ones came in. new ones still in a box in the basement. Can't even tell anything was done.
08 Ford F-350 SD PSD CC
10 322 Fuzion Touring Edition II
07 Can-Am Outlander 800
08 Can-Am Renegade 500
