cabanaman
florida
In my experiance yes,I can go 90 degrees.My box is above the rails about 4".
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
fred42
Charlotte, NC, USA
I had a box in the front, but had to make room for my HCCR Steps. I went with a rear toolbox from here. Although it is a bit awkward to use when hooked up, I enjoy having the tailgate as a working surface when unhooked.
If you use a rear one, you can't just be below the rails, you have to account for the drop and swing of your pinbox. In my case I had to go with a 16" high instead of the 19" high.
2001 F350 SC DRW V10 5spd 4x2
2012 Evergreen Everlite 31RKS-5
Allworth
Orlando, FL
I had one below the rails on my previous short bed (with a soft tonneau cover). I now have the front section of a fold-a-cover partitioned off with plywood across the bed to make a lockable storage area. I can cary ice chests or storage boxes behind that without interfering with the hitch in an 8' bed.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
nremtp143
Georgia
I have low profile toolboxes in both of my duallies. No clearance problems at all.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
crickeydog
Marietta, Ga.
Majikal-Joe wrote: Can I put a tool box in the front of a 8' bed and have room to turn?
You bet!!! I have a low profile tool box in front and behind our 5'er hitch. Both are full and I have no clue where'd I'd put that stuff without the boxes. Since you have a slider hitch I can't way for sure if a box will fit behind your hitch but it'll darn sure fit in front of the bed.
Happy camping!!! See y'all down the road!!!
USAF RETIRED. "EITHER LEAD, FOLLOW, OR GET OUTTA THE WAY"!
PULL DOGS:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT "THE SILVER FOX" PRIMARY
2000 DODGE 3500 QUAD CAB DRW CTD LARAMIE "THE ROAD TRAIN LOCOMOTIVE" BACK-UP
2004 HOLIDAY RAMBLER PRES. 30 SCD 5'ER
cpmanz
Bellflower, CA.
Bed height and/or low profile tool boxes are both acceptable, there are also other tool boxes as in the above posts that are specifically designed for 5th wheel usage
Cpmanz
'06 Montana Mountaineer 336RLT
'03 Ford Crew Cab 4X4 6.0 PSD, Banks
Past RV - '97 Pace Arrow Vision 33L
johnvb
Virginia Beach /Virginia/USA
No problem here. Husky box from the Home Depot. Not the best, but good enough for camping stuff.
Cummins12V98
on the road
fred42 wrote: I had a box in the front, but had to make room for my HCCR Steps. I went with a rear toolbox from here. Although it is a bit awkward to use when hooked up, I enjoy having the tailgate as a working surface when unhooked.
The Idea behind this type of tool box is you don't need a tailgate.
It would be much easier to use if you removed your tail gate.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Cummins12V98
on the road
If you want the best quality tool boxes look at www.highwayproducts.com and click on 18 and 28, they show the 5th wheel toolboxes. I have the one at the front of the bed. Mine is 63 1/2 wide 30 deep and 20 high. Mine is out of my 98 Ram and it is wider than what they spec for my 11 Ram. Mine squeezes between the eye hooks at the front of the bed on the sides. I would take some measurements if you have a Ram and want it as wide as possible talk to them and say what I did. My Dad bought a new one for his 12 Ram and it has big gaps on the sides.
I was lucky I found mine on Craigs list for $300, I think they sell for around $1,000.
bigdaddyf350
SoCal
I've got one also with no problems I have it at about 2" above the truck bed and can turn and clear it pretty resonably although I do think that if I were to be turning at a significant radius and at the same time in a very odd hilly or offroad situation I could possibley hit the top of the tool box but have to this day never come close!
