Since this summer has been so blasting hot across the country I thought I would ask, Has anyone else with the Voltage had any issues with their A/C. We went for a weekend trip and with outside temps around 95 we could not get our coach to cool below about 84 or 85 degrees. I had a 29 foot TH / TT with one AC unit and we could keep it frosty. Tips tricks or comments would be greatly appreciated.
One other question for the Voltage owners. When I put my main slide out, the floor does not lower to become somewhat flush like I have seen in many other RV's. Does anyone else have or had this problem. Is it an adjustment issue I need to take it back to the dealer for. All help and comments are appreciated.
I have a 3600. My main slide goes to relatively flush, but it's my couch and dinette, so I dont really notice.
I have not had the issue you describe with the A/C, but I've only had mine on a handful of times. When I used it, it got cold. (I have to pay for electric at my CG, and I'm cheap, er-THRIFTY)
The only tip I can give is if you arent using a section (garage) close it off and close the vents.
One of the things I do is keep my night shades closed all the time and the blinds at least mostly angled shut to minimize the amount of sunlight to the inside. I also use my fans a LOT. I also happen to be at work during the hottest parts of the day.
