driver75
tomah
The tires on my fifth wheel are 11 years old they look very good no cracks and real good tread I drive less than a thousand miles a year and the unit is inside all winter Should I be changing tires or are they ok. The name on the tires are All Country and the size is 235/85/R16 E range.
jetboater454
Camping or home
I would change them.Looks can be deceiving.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Go Dogs
South of Pittsburgh, PA
Get new tires. It's not just the miles, it's the years-even if they look good.
Road Runners
Tampa Bay, Florida
Most of what I have read indicates that regardless of tire looks they should be change at around seven years. But, since you don't drive and keep your fifth wheel garaged I don't know if the seven year recommendation holds for you. If it were I would probably opt for putting on new tires.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
REWahoo
Texas Hill Country
I would absolutely get new tires. You are ripe for a blowout causing damage to your wheel well and you'll end up having to foot the bill to repair that plus replace your tires.
2011 Silverado 2500HD LTZ Duramax 4x4
2007 Jayco Eagle 291RLTS
Beverley&Ken
Tottenham,Ontario
I would change them, unless that 1000 miles is divided into many short trips where the tires never get hot or your speed is below a speed that would not result in damage to the RV if one does blow out.
Beverleu and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Veebyes
Bermuda & Maryland
Hmmmm, 11 years old, spent most of the time indoors not exposed to UV, don't put many miles on them, looking good, I'd run them some more but keep a close eye on them.
2007 Alpenlite 34RLR
kzspree320
Louisiana
I would change them. They have served you well for a long time, but I would not risk major damage to the fiver from a blowout. I would have changed them about 4 years ago, so you are well ahead of me on saving tire money. Good luck.
JIMNLIN
out here
Dry rot inside the tire can't be seen from the outside. I would mount new tires and sell the old ones to someone with a utility trailer.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Chuck&Gail
In the Colorado Mountains
If it was mine I'd change them. Tires do too much damage when they blow out. For me the risk would outweigh the cost.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
