RV.Net Open Roads Forum: Tech Issues: 5th wheel water pump stops working
 > 5th wheel water pump stops working
Lonald
Sonora
Posted: 08/09/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
My 5th wheel pump stopped working and some jiggling made it start again sometimes. COuldn't correct the problem so bought a new one and just installed it today. It only works sporadically, too. What might the problem be?
Stop the press... my wife was trying to help by sending out this message while I was working on the rig. Through a trouble shooting process, I've determined I also have a bad switch. The system is working fine now! Thanks for all of you who were quick to respond!
* This post was edited 08/09/12 08:44pm by Lonald *
Old-Biscuit
Across the USA
Posted: 08/09/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Loose wires........check wiring connections at pump and at switch.
Also check for broken insulation/wiring from switch to pump.
Save that old pump as a spare/back up or can be used as a water transfer pump.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
pulsar
Lewisville, NC
Posted: 08/09/12 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
joelc
Milford, PA
Posted: 08/09/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Is the pump running without pushing the water, or does the pump itself not run. If it does run do you get water, and how long does it run for.
I am asking these questions for trouble shooting purposes. You might also try hooking it up to a battery if it is pumping then stops. This would tell you if you have a faulty connection somewhere.
