RV.Net Open Roads Forum: Tech Issues: Silicone RV sealant and silicone removal
 > Silicone RV sealant and silicone removal
bighatnohorse
Gig Harbor - Cave Creek
Posted: 08/09/12 05:23pm Link  |  Print  |  Notify Moderator
They sell this silicone RV sealant at a nearby RV shop.
I talked with one of their techs and asked about silicone removal.
He said you can get silicone removal products at auto parts store - their shop didn't sell it because they buy it by the 5-gallon buckets.
Has anyone used this, or similar, silicone product on their RV?
Have you had experience with a silicone removal product?
What is your experience with it?
2014 Lance 1181
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“Travel is fatal to prejudice, bigotry, and narrow-mindedness. . ." -Mark Twain
therink
Western New York
Posted: 08/09/12 05:41pm Link  |  Print  |  Notify Moderator
Do not use silicone on the exterior of a rv. It will not bond to aluminum, fiberglass or plastic for very long. The correct sealant to use is a urethane based caulk. Try Dicor or ProFlex brand RV sealants. Lap sealant is for sidewalls, markerlights, etc. Self leveling sealant is for roof seam and fixture penetrations. Any rv supply store will carry the correct sealants. You can also Google the brands I mentioned and buy them there.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Mammoth-Snowman
Mammoth Lakes
Posted: 08/09/12 06:24pm Link  |  Print  |  Notify Moderator
Nope, but I am going to buy some.
Rig: 1995 Jamboree Searcher 23 feet
http://www.discovermammoth.com
brirene
midwest
Posted: 08/09/12 06:37pm Link  |  Print  |  Notify Moderator
X 2 what Steve said.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
ADUS
Indiana
Posted: 08/09/12 07:01pm Link  |  Print  |  Notify Moderator
Steve nailed it.
3 tons
CA.
Posted: 08/09/12 07:17pm Link  |  Print  |  Notify Moderator
I've had good luck removing silicon with naptha from Ace hardware...
Best Regards,
3 tons
Wherever I happen to park
Posted: 08/09/12 07:20pm Link  |  Print  |  Notify Moderator
Most of the Silicone products I've tried are very easy to remove.. In fact...
If they are in a spot where I wish for them to stick, they remove themselves.
If they are in a spot where I do not want them to stick they .. Stick like glue.
I have used other products, Dicore lap sealant, Goop, Urethane sealants, and more, all work way better where I want them to stick.. alas they also work better where I don't want them to stick.
Home is where I park it.
Bobbo
Wherever I park
Posted: 08/09/12 08:08pm Link  |  Print  |  Notify Moderator
Nothing with the name silicone is allowed within 100 feet of my RV.
Bobbo, Linda and the furry kid (45 pound rescue)
Dave H M
IL
Posted: 08/10/12 06:17am Link  |  Print  |  Notify Moderator
I cannot understand why people get so worked about not using silicon on an RV (not rubber roof of course).
I am talking good quality stuff.
Isn't that the stuff that holds aquariums together?
How to remove trhe quality silicon I use is the last thought on my mind.
Chris Bryant
Arden, North Carolina
Posted: 08/10/12 07:09am Link  |  Print  |  Notify Moderator
I use silicone occasionally on trim- using a good quality RTV silicone, with proper prep and it works fine, though most often I use it for cosmetic purposes- like around windows and doors (hint- the seal is between the frame and the body, not around the edge where I use the silicone), or for gasketing applications. I remove it with 3M brand "Silicone and adhesive remover" and plenty of paper towels.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
