I am in the process of sanitizing my potable water tank...the literature I read about it says to empty the hot water heater when draining the bleach water out. How do you do that? Is removing the anode rod sufficient to drain the hot water heater?
. Should have read this before the water pump post
Don
Perrysburg Dodgeboy 2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
I don't have any check valves, so if I uncap a cold low point drain and open a hot water faucet the water heater will drain. It's the same as popping the safety valve but without the risk of having the valve leak afterwards.
I pull the anode rod and flush the tank at the end of the season.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
