Indiansprings
ARIZONA
Thanks guys. Nothing seemed bad, power was there I just wanted to keep the EGT down around 1300.
2013 28 Attitude w/slide, 06 SuperDuty 4x4 CC BulletProofed ARP studs 6.0, Icon 4.5",AFE Exhaust, Coolant Filter, SCT, CTS Monitor, 08 Diff cover, Derale trans pan, Phoenix AMSOIL Dealer, Dual Bilstein stabilizer,SuperGlide 16K, Nitto CROSSTEC 275/70R-18,
steelpony5555
Copperas Cove Texas
Whaaaat???? I think they designed these trucks to tow in any kind of heat we have. If they did not then there woould be a lot of upset Texans as well as Arizonians. If it's not staying cool then you have a mechcanical problem
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
Indiansprings
ARIZONA
I am glad to hear that 230 degF isn't to bad pulling a steep 5 mile hill. Came right back down to 205-210 when I leveled off.
C Schomer
Buckeye, Az.
Those temps sound normal to me. I back off when the water temps hit ~225. If my autos wouldn't have gotten over 190, I wouldn't have switched to manuals. I'm due for a coolant change. I've kept it well maintained but I will do a chemical flush to be on the safe side and I already have RP purple ice to try out. Craig
03Dodge QC HO CTD Dually NV5600 4.10 Rear/WD A2K turbo, TST/PMCR, 4" exh, PRXB Pacbrake, Rancho 9000s, FS Airbags, Onboard air/in-cab controls, Custom hauler bed. 98 Sunnybrook 30RLFS 5er WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
fly-boy
Los Angeles, CA
190 on the trans is normal.
230 on the coolant is normal.
Those are both vary safe temps-
2012 GMC 3500 Denali Duramax 4x4
2009 WW HKD with a big garage
A few toys
edm3rd
Tennessee
If you drive the same route again, try it with the a/c off and see how your temps compare (especially if ambient temperature is similar to your first trip).
LVJJJ
NW WASHINGTON
Chuck&Gail wrote: For radiator add some Redline Water Wetter. Sure helped our last TV.
I use water wetter too in my 65 Chevy van 292 6 cyl tow vehicle and it does work. I also drained about a gallon of antifreeze out and replaced it with a gallon of distilled water. Pure water cools a lot better than antifreeze.
1965 CHEVY VAN, 292 "Big Block 6"
1985 WILDERNESS 3000CL
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
edm3rd
Tennessee
50/50 antifreeze/water mix will cool best.
If it stays cooler by draining some existing coolant and replacing with water, your % antifreeze was too high.
Turtle n Peeps
California
edm3rd wrote: 50/50 antifreeze/water mix will cool best.
Actually, pure water will cool best. Problem is it will also boil sooner.
outside the fire"
edm3rd
Tennessee
Turtle, I stand corrected.
Do you run water or water/antifreeze mix ?
