RV.Net Open Roads Forum: **Weighed camper and truck ** UPDATE STEERING AND SWAY
 > **Weighed camper and truck ** UPDATE STEERING AND SWAY
billyray50
Dallas
Posted: 08/10/12 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Ok Let me have it guys !!!Weighed Truck and camper with camper empty!! Since we already unloaded a week ago from our trip.
Truck only at cat scale with full tank of gas and me at 180 lbs:
Steer axle: 4340 lb.
Drive axle: 2740 lb.
Gross weight: 7080 lb.
Truck placard sticker on door:
with stock tire: 265/70r/17
GVWR: 9000 lb.
Gawr front : 5200 lb.
Gawr rear 6010 lb.
Truck and DRY camper with me at 180 lb. and full tank of gas:
Steer axle: 4640 lb.
Drive axle: 5760 lb.
Total gross weight: 10400 lb.Total gross weight: 10,400 lb.
I guess it doe not look too good before we are even fully loaded wet weight???
* This post was edited 08/10/12 06:06pm by billyray50 *
johnrbd
San Joaquin Valley
Posted: 08/10/12 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Think you have the right idea.
Eycom
32043
Posted: 08/10/12 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
There's a reasonable solution. Make the wrong decision right. Travel safe.
RVn Full-time
billyray50
Dallas
Posted: 08/10/12 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ok let me hear some solutions if it was you..Thanks
Butch50
Bentonville, AR
Posted: 08/10/12 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Well now you know where you are at instead of just guessing. As you can see campers get heavy really quickly.
Good luck
Butch
2011 F350 KR 4X4 CC LB SRW
2012 Northern Lite 10 2 CDSE
2008 Custom Weld 17' Boat
2010 Can-Am 650XT Outlander Max
2012 Harley Tri Glide
Eycom
32043
Posted: 08/10/12 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
If faced with having to carry 10 lbs. of sand in a 5 lb. sack, would you...
a. make two trips
b. be satisfied with 5 lbs of sand
c. get a bigger sack
BradW
Mayor of Flat Rock
Posted: 08/10/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
That is surprising to me that 3,000 lbs went on the rear axle and only 300 lbs went on the front axle.
I would have thought that an 8-1/2' camper in an 8' bed would have put more weight on the front axle.
Well, looks like you are under the GVAWR's, but dry and with no gear.
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
billyray50
Dallas
Posted: 08/10/12 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
No it is a long bed
billyray50
Dallas
Posted: 08/10/12 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
and the camper was empty dry weight..
campn4walleye
Central WI
Posted: 08/10/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Billy,
A recent discussion was just held on this subject. It sounds like you have 2 logical options: buy a 1 ton SRW and $6000 in bigger wheels, airbags, etc (as you'll still be too heavy for the SRW) or buy a dually and have peace of mind.
We looked at your unit up in Tomahawk and ran the weights. We would have been 700lbs overweight.
This is JMO from someone who is new at this, but have done my research. No matter how hard you try, the weights don't change.
So far you TC experience has been frustrating, don't make it worse by trying to fit a large TC on too small a truck.
I don't care what Adventurer says...most of their TCs are too large for a 2500 or even a 1 ton SRW without many expensive mods. I told them that they should stop advertising them as such. It's misleading. RUN THE WEIGHTS.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
