RV.Net Open Roads Forum: gas to carb not to sparkplug on genset
Search only in Toy Haulers
 > gas to carb not to sparkplug on genset
Ropdoc
California
Posted: 08/11/12 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Hello friends,
The genset is a 5500 Marguis, gas.
I just installed a new fuel pump on my genset. I did this because it was not working. Now I have gas to carb. I have drained the bowl several times. But not getting gas to sparkplug. If I spray carb cleaner into carb it will fire up for a second then die. I am not a mechanic so be gental with your advice. I am out now trying to get this finished. And I need to do it myself because of money issues.
I thank you all so much for your advice.
Dave
Dirtclods
Newport Beach
Posted: 08/11/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you jets are clogged up. If there is spark then it is likely to be a fuel problem of either too much (flooded) or too little which could mean dirt in the fuel that has got into the carburettor and clogged the small passages inside the carburettor which would then mean a cleanout.
Red,
Southwest
Posted: 08/11/12 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Save yourself some time & a headache . . .
Just get a new carb for it .
Red, *<(:{)-
Ropdoc
California
Posted: 08/11/12 11:28am Link  |  Quote  |  Print  |  Notify Moderator
How much is a carb? I just spent $118 on the fuel pump.
Sloop Smitten
San Marcos, CA
Posted: 08/11/12 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Before you spend money on the a new carb pull the carb bowl off your current carb and give everything inside there a good wash with an aerosol carb cleaner. It sounds like the jet that the float opens and closes is stuck shut. If you can remove that jet and give it a good cleaning that may be all you need. If you cannot remove it give it a good wash and work it up and down a few times to try and dislodge it. If you are going to purchase a new carb try "SearsPartsDirect" online. They have a pretty good selection of small engine parts there. You will need the Onan part number for your carb to search.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
Ropdoc
California
Posted: 08/11/12 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunetly the carb is a non serviceable carb so I would have to buy a new one. I have been using carb spray to see if I could get anything to loosen up but no suck luck.
Ropdoc
California
Posted: 08/11/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
well i bought a new carb @ $270. But it is running great. We ran 2 Ac units at the same time. No problems! Just ran out of gas.
So now I am running it once a week.
Thank you guys for the advice.
Dirtclods
Newport Beach
Posted: 08/11/12 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Here's some great info:http://www.flightsystems.com/pdf/onanrvtshootgd608.pdf
Dirtclods
Newport Beach
Posted: 08/11/12 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Does it have a inline fuel filter?
Ropdoc
California
Posted: 08/11/12 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yes 2. One before the pump and another before the carb. We are good to go. Camping next weekend. House sitter all ready to go.
