RV.Net Open Roads Forum: Tech Issues: surge protector lifespans
 > surge protector lifespans
joelc
Milford, PA
Posted: 08/11/12 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Progressive Industries Surge/EMS hard wired. I know that the unit is modular, so if there is a problem, and it is out of Warranty you just remove the module that is defective replace it. You should not have to purchase a new unit unless the entire thing went for some reason. Don't know if Surge Guard is the same?
Triker33
Homestead, FL
Posted: 08/11/12 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 30AMP Surge Guard burn up at the post. A few years ago.
The replacement one still working good.
Bought a Frank's autoformer a year ago(3/11). And never did get it to work.
It keep tripping the built in 30AMP breaker. So a couple weeks ago I changed the breaker out for a 35AMP one. Same thing after 5 minutes it trips.
I checked with Frank's and the warranty has pasted. And they can't help.
Their engineer said:
Electrical Engineers have come to the conclusion that -
Your Surge Protection, EMS, 13.5 BTU A/C, 12 cu.ft. Refrigerator, Electric hot Water Heater, Directv Rec'r, TV, Inverter/battery charger ALL ON at the same time as you stated are overloading the Voltage Booster. Since it is out of warranty there would be a charge to checkout and service the VB.
That is BULL SH** as I can also run my 2nd AC plus all the above and not blow the inside or post 30AMP breakers. And I put a 35AMP breaker in the autoformer and it was still tripping being feed by a 30AMP breaker.
May try the PowerMaster next if I keep seeing good reports from users.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
Banks Powerpack
DataStorm SatMax5 | VMSpc | Pressure Pro
08 HHR LT2
Click here to see where I am
ryanallie1
Magalia, Calif
Posted: 08/12/12 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
I guess you have some bad luck, or your power ocrds are not in very good condition.
We to, have had our Portable, Progressive 30 AMP Surge Protector, and Lock Hasp for at leaast 10 years also. We have used our Surge Protector on our lat 5er and on our Motorhome as well.
We always used our Portable Surge Protector, connected right at the Power Pole with the Lockiing Hasp. Never had any issues with it or anyone bothering it. We did how ever, cover the Surge Protector with a big Black Plastic Bag, durning some pretty wet weather, just to be on the safe side.
For our Motorhomes use, we have an extra 25 ft 30 AMP Power Cord. So we just plug our 30 AMP Surge Protector into the Motorhomes Power Cord, and keep the Portable Surge Protector inside the Storage Compartment, and use the spare 30 AMP Power Cord to the Power Pole.
That way it keeps it out of sight, and out of any weather issues. And we have not had any issues using the extra 25 ft of extra 30 AMP Power Cord.
I aways check the Out-Lets on the Power Poles, to see if they are Damaged or Burnt areas. I also keep all of my Power Cord ends clean, and always shined up, and use some Die-Electric Grease on them also.
Our 30 AMP Surge Protector has saved us a few times, both for Low and High Voltage. We also have a "Voltage Meter" plugged in all of the time, so we can see our incomming power at a glance.
We have been very pleased with our Progressive Portable 20 AMP Surge Protector. And think it has been money well spend. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Airstreamer67
Pineville, LA USA
Posted: 08/12/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I've had good luck with the 30 Amp Surge Guard and Hughes Autoformer for the past 10 years.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/12/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Link To A Good Guide About Surge Protectors
EATON PDF GUIDE TO SURGE PROTECTION
Google It (not linkable)
ploiselle
South Shore, MA
Posted: 08/12/12 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting since I picked up a used Frank's 30 amp that is also is dropping out. At first I thought it was a thermal overload, but it works fine at home on bypass and low boost. It definitely drops out at a state campground on high boost. The time varies from 10 minutes to many hours before it fails. My Progessive EMS says that I am drawing between 15 and 20 amps with the front a/c on etc.
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
MrWizard
Traveling
Posted: 08/12/12 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
to the OP
check your circuit breaker panel
make sure your loads are equally divided, so that both legs are sharing the load, not good If both A/c's are on the same power leg
with too much load on one leg you could be over heating one side of the autoformer boost windings
also is this hardwired, is there any ventilation in the compartment
assuming your main concern is your A/C units, you are going to be pulling a lot power and creating a lot of heat
the autoformer needs to be able to dissipate that heat
minimizing the load by tuning off the WH during the day might also help
* This post was edited 08/12/12 10:00pm by MrWizard *
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
sljkansas
Miami Co. Kansas
Posted: 08/12/12 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Progressive Industries 50amp portable unit,and had to send it back once and they repaired it free of charge under their lifetime warranty. Is has saved use from low voltage this year. Voltage dropped to 104vac then to 71 vac. The power co. had a main power line problem about 10 pm, and had it fixed about 12:45 am.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
sljkansas
Miami Co. Kansas
Horizons28
Brevard, NC
Posted: 08/13/12 06:15am Link  |  Quote  |  Print  |  Notify Moderator
"If both A/c's are on the same power leg
with too much load on one leg you could be over heating one side of the autoformer boost windings..."
We have only one AC.
"also is this hardwired..."
No, they were both portable units.
