RV.Net Open Roads Forum: Towing: Towing uphill
Search only in Towing
Open Roads Forum  >  Towing
 > Towing uphill
maagk
Greensburg, PA
Posted: 08/11/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
How would you climb a mountain from a dead stop. Going to a dog show site that at the bottom of the mountain there is a traffic light. How do you recommend that I climb the hill from a dead stop. Last year I did get the light red and creeped up the hill in drive. I have an automatic with overdrive. Thank you in advance.
rhagfo
Portland, OR
Posted: 08/11/12 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Please describe the ""Mountain" how steep, how long?
What is your TV and what and how much weight are you towing. What is your gear ratio.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
maagk
Greensburg, PA
Posted: 08/11/12 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Ford explorer, 20' travel trailer, i do not know the grade, but it is called 3 mile hill. I am a single woman and have no idea what the gear ratio is.
Terryallan
Foothills NC
Posted: 08/11/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off the overdrive, Put it in drive, and mash the gas. it will go up in the best gear it can, at the best speed it can. It's an Auto. Let it do it's job. However, coming down is different. Use a gear low enough to keep you from riding the brakes, be it 2nd, or even 1st. Start down in that gear, and go slow. again, turn off the overdrive.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
Mark Kovalsky
South Florida
Posted: 08/11/12 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Push your right foot as far down as you need to so that it goes the speed you want to go. If the trailer is within what your Explorer has been rated to tow it was engineering to climb that grade with the trailer with no problems. Turning off the overdrive won't make any difference, it won't be going fast enough to get into overdrive.
When I was a Ford engineer I ran tests just like this. There was an eight mile grade that we had to climb starting at a red light at the bottom. We did the test only when it was more than 95°F outside, and with a trailer that was weighted to be at the maximum the truck was rated to tow. In some cases I planted my right foot all the way on the floor and didn't lift it again until I crested the peak, eight miles later.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
rockhillmanor
On the Road
Posted: 08/11/12 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Which show are you going to? Are you going by the directions in the premium list?
Many times the directions in the premium list is NOT the best way to get there. I've almost killed myself a couple of times with the MH towing, following those directions. My bet is there is another better way in to the show site.
I've been to almost all of them maybe I can help you out avoid the steep grade.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
smkettner
Posted: 08/11/12 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Floor it, ease up for the 1-2 shift and hold 2nd at full throttle to the top.
675 watts solar
ScottG
Bothell Wa.
Posted: 08/11/12 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
When descending a hill, it's best to use quick jabs to the brakes rather than riding them at all which makes them hot and less responsive.
Scott, Grace and Wesly
H0NDA eu2000i
maagk
Greensburg, PA
Posted: 08/11/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I am afraid I will blow up engine. Last year the tach was very high and it scared me. I do watch the tach always when I am towing and someone told me to always turn off the OD. I do know to go down grade to down shift, but I did not know if I had to down shift to go uphill.
chevyman2
missouri
Posted: 08/11/12 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
You dont. As you already know, Do not tow in OD. Leave in reg drive and just hit the gas and go uphill. All OBD II cars (computer talk) "this includes your Explorer" has a safety built in that will not allow your engine to overrev. It will shut it down before it blows up.
You will be fine. Mash the skinny pedal on the right and let her go.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 95 Palamino PUP
When I grow up I want to be retired.. THEN I WONT HAVE TO GROW UP AT ALL!!!!
 > Towing uphill
