RV.Net Open Roads Forum: Technology Corner: Two TVs, different channels
 > Two TVs, different channels
Jim Norman
NJ
Posted: 08/13/12 04:26am Link  |  Print  |  Notify Moderator
We have two TVs, one in front ans one in the bedroom. The front TV on either Cable or Air gets more and clearer channels than the one in back.
Suggestions?
2016 Tiffin Allegro Red 38QBA
2008 Jeep Liberty (aka FireToad)
Poppy & Nana
Upstate New York
Posted: 08/13/12 05:01am Link  |  Print  |  Notify Moderator
watch the front tv!!!!!![emoticon]
Leo & Kathy
Upstate, NY
in the Adirondacks
2013 Rubicon 2900 Toy Hauler
2008 - Ford F250 Super Crew 4x4
Alfred622
Rochester, MN
Posted: 08/13/12 05:03am Link  |  Print  |  Notify Moderator
Same brand of TV? Same signal fed to each? If you bring a portable into the bedroom and hook it up to the cable you might be able to eliminate either the cable or the TV as a problem....
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
2Macs
Indianapolis, IN
Posted: 08/13/12 05:44am Link  |  Print  |  Notify Moderator
Some brands of TV's are more sensitive about finding channels in a channel search. I have two different brands of digital TV in my TT. The one in the bedroom finds more channels than the one in the living area.
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 08/13/12 05:47am Link  |  Print  |  Notify Moderator
Our does the same. More channels on the bedroom tv.
D.E.Bishop
Eagle Rock, CA
Posted: 08/13/12 05:53am Link  |  Print  |  Notify Moderator
I would bet if you paralelled an RG6 cable from the switching box to the rear TV and used that, you would eliminate the signal problems. I love my coach and think it has great features but there were three pieces of coax from the antenna to the booster switch, which in a straight line is a distance of three feet at best. That's two couplings and one of the connectors was not too good. Signals to both TVs were terrible and when I measured the voltage from the boster switch to the antenna is read from 11.5 to 12.5, not good to be able to wiggle the cable and change the readings. Changed out to one piece and no more problems.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
skipnchar
Topeka or somewhere else
Posted: 08/13/12 07:17am Link  |  Print  |  Notify Moderator
Televisions are not all created equally nor are connections. Swapping TVs and seeing of the problems remain with the set or the connection would be one way to find out which is your issue.
rockhillmanor
On the Road
Posted: 08/13/12 08:06am Link  |  Print  |  Notify Moderator
This is very true with the digital TV's. My little tiny Vizio gets far more channels than my big screen does. And the channel number a show is on varies between the two TV's also.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
SRT
Head of the Lakes, MN
Posted: 08/13/12 08:43am Link  |  Print  |  Notify Moderator
Suggestions?
Check your cable connections (how do I know).
Wherever I happen to park
Posted: 08/13/12 01:24pm Link  |  Print  |  Notify Moderator
In my 37'7" motor home there is close to 50' of cheapest bidder RG-59 between the two TV's. plus a couple of decent connections.
My suggestion, Quality RG-6
Home is where I park it.
