rowekmr
Chicago
I'm sorry was too busy this week to even take a look. Thanks for all the info and suggestions. I will take a look under it to check the connectors and the motor. I will try the tap on the motor case if I can reach it. If it is the motor I hope mines is also a power window motor that are common and cheap. Are the motors easily accessible?
03 Ford Excursion Ltd 6.0L
00 Acura RL
08 Jayco 31 BHDS G2
96 Regal 258 Commodore
1 Wife 3 kids
dcbrewer
kentucky
Mine done the same thing on last trip, checked all the power, all good, took the advice I got here and hit the gear box with a hammer, and all is well for now!! also give it a good greasing.
zert800
Steinbach, Manitoba
And remember to check the fuse!
go hard or go home
charles
Ohio
Low chassis battery seems to be one of the common problems. I'll second the "watch your fingers", especially if your out in a storage lot somehere alone.
Nick
rowekmr
Chicago
I had the motorhome plugged up at home so I thought that would eliminate the low battery issue but maybe not. After not working for awhile yesterday it starts working. Since it is at my house I turned it off to save whatever limited use of it I might have left. I might just defer this maintenance until the next time I take it to the shop.
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Circuit board .
rowekmr
Chicago
UPDATE:
My parents came in town and I turned the steps on so they could board the MH but when we exited it and closed the door the steps wouldn't retract all the way yet I heard the motor. I took a look under it and it seems the arm that moves the steps broke at the attachment point. Any suggestions?
John & Angela
Full Timers in Canada, USA and Mexico
rowekmr wrote: UPDATE:
Take it off, take it to a machine shop and tell them to call you when it's fixed. Then put it back on.
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
fischer
livingston, tx
You can google the manufacture and probably get a new part if the local guy cant weld it. good luck if it is a keywee I have a manual and others probally do too.
2005 Southwind 32vs F53 Retired
2006 Jeep Liberty 4x4
Blue ox Tow Bar
Jerry B
Lake of the Ozarks
I googled the part no. and found one in Phoenix for $12. As far as the motor NOT working, I smacked the motor with a hammer and it has worked for all this summer. I believe it is a dirty or corroded armature.
Jerry B
Mobile Suites 36TK3
