RV.Net Open Roads Forum: Class A Motorhomes: Flexsteel 6 way power seat wiring?
 > Flexsteel 6 way power seat wiring?
cvbdsl
Winchester, ON
Posted: 08/14/12 05:50pm Link  |  Print  |  Notify Moderator
Anyone have a wiring diagram for the Flextsteel 6 way power seat(1999 DSDP)?
I just replaced the seat on the pedestal after doing the flooring and everything worked fine until I swiveled the seat. No power after that and it is fully forward so makes entry exit a bit awkward.
I did find a red wire that seemed to have been pulled out of a splice (compared to the drivers seat switch) but putting it back didn't do anything.
I also found a badly frayed wire (blue) and am wondering if I may have shorted a fuse somewhere, but can't find a fuse for just the passenger seat (drivers works fine).
Would appreciate any advice.
Thanks
Chris
2008 Holiday Rambler Scepter 42 PDQ
2013 Ford Edge - Ready Brute Elite Tow Bar/Blue Ox Base plate/Patriot Brake System
Retired Canadian Army WO (1971-2000)
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 08/15/12 11:13am Link  |  Print  |  Notify Moderator
Little doubt you blew a fuse. You need one of these in your tool boxes. Can be found for a few bucks or more. 12 volt test light
Compare the good one to the broken one and then chase the wire that should be hot which is probably the red one. Check your fuse panels using the same test light. Check each side of the fuses. Might be an inline fuse in a panel next to the passenger. When you check the wires for voltage check both sides of the connectors. Might not be making contact once you plugged it back in.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
Blaster Man
Posted: 08/15/12 01:04pm Link  |  Print  |  Notify Moderator
I had the same problem...a wire had pulled out from under the seat when the chair was turned. Be sure you checked ALL the wires.
2014 American Eagle
cvbdsl
Winchester, ON
Posted: 08/15/12 02:52pm Link  |  Print  |  Notify Moderator
Thanks, i think the light is good, might be easier to see than the meter.
As to other wires being off I'm afraid I'll have to remove the seat again. PIA because of the cable that releases the catch for the swivel.
thanks
chris
cvbdsl
Winchester, ON
Posted: 08/16/12 02:16pm Link  |  Print  |  Notify Moderator
Found the problem after stripping the cable protector and the electrical tape. The power wire was just pulled out of the connector, planning to splice in a few inches so this wont happen again.
OTH still don't know what the loose red wire is for, the seat works fine with or without it spliced into the orange power wire on the seat switch itself. Suspect it still may have something to do with the non-functional air bags for the lumbar support.
Thanks
Chris
