RV.Net Open Roads Forum: Tech Issues: Determining Wattage of Solar Panels?
 > Determining Wattage of Solar Panels?
Woodtroll
Appalachian Mtns, SW Virginia
Posted: 08/14/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, folks,
Years ago, I bought two used PhotoComm, Inc. MSVX-24 solar panels. That's pretty much all the information that is on the tag, and attempts to search these panels' specs out have been fruitless. I know how to test for voltage and short-circuit amperage, but based on these readings how do I figure out what these panels will actually return to my batteries through my Morningstar Sunsaver 6 charge controller?
Thanks,
Regan
2003 F250XL 4WD 7.3L Crewcab LB; 6 speed, Receiver hitch; Prodigy brake controller; Big Tex grille guard/ deer deflector. Canoe hauler and camping truck extraordinaire!
2003 Layton 242 Scout- Extra batteries, solar panels, and propane for boondocking!
harold1946
Surprise Arizona
Posted: 08/14/12 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
www.ampstowatts.com
If the amp output is not listed,put the panel in full sun, read the amps and then do the conversion.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
BFL13
Victoria, BC
Posted: 08/14/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Based on my limited experience, the Isc you take at high noon is pretty close to what the panel will do for amps into the battery at high noon. Ignore Voc, it is just goofy--use the Isc which works ok.)
Two panels will do twice that. You need a way to get your full daily AH haul, depending on the 'bell curve' you get for amps all day depending on your location and time of year. A Trimetric is good for that job)
Your actual panel wattage does not matter very much in real life. The way they work is that the max power (panel rating in watts) occurs with fewer amps than Isc (called Imp at Vmp) --it's all BS. Ignore it. Just get your max amps at high noon on a sunny day with the panel oriented properly (South tilted up for your Latitude and time of year) and work with that.
Here are the amps I got various ways, so you can take your noon amps and plot your own bell curve in proportion.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26065604.cfm
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
MrWizard
Traveling
Posted: 08/14/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
you have the numbers
just compare them to the values for available panels
or post the numbers here and we will give you are best guess
since these are most likley 12v system 24rated watts
being used on a 6 amp controller
if i put an amp meter on the circuit , it will likely show just over 3 amps charging
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Woodtroll
Posted: 08/14/12 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, folks. I just wasn't sure what voltage to multiply the amps by- 12, 14 out of the charger, 17 out of the panel, etc.? From what BFL13 says, it looks like I'm complicating it too much! I'll test the panels the next sunny day we get when I am home at noon, and post the numbers.
I appreciate your help! Take care,
Regan
BFL13
Victoria, BC
Posted: 08/14/12 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I was ASSuming the Voc would be around 20 so it is a 12v system at 17ish volts Vmp.
You can have 24v system with Isc in the 8a range. So my post above would not apply if it is a 24v system.
* This post was edited 08/14/12 08:37pm by BFL13 *
Woodtroll
Posted: 08/15/12 04:44am Link  |  Quote  |  Print  |  Notify Moderator
No need to apologize- your assumption is right! It is a 12-volt (nominal) system. Your post is very helpful. I'll put the numbers up (probably tomorrow before I have a chance to get the readings) and let y'all see what you think.
Thanks again!
Woodtroll
Posted: 08/16/12 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, folks,
I managed to test these panels today in somewhat less than full sun (about 3:00 in the afternoon). I got readings on both of 20.9-21.0 volts open circuit and 1.29-1.30 amps short circuit, depending on how I juggled the panels, meter, connections, etc. with only two hands! It looks like these are at least 24-watt panels, I think (?).
Thanks very much for your help! Safe travels,
Regan
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/16/12 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Are those panels with cells on a white background that may be yellowing in places?
Woodtroll
Posted: 08/16/12 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
They do have a white background, but no yellowing that I can see. The white shows through only as very fine margins- almost all the panel is covered by the cells.
