bluwtr49
Green Valley, AZ
I use a 150 psi Viair portable and the Jeep as a power source. Works perfect. Only take a minute or tow to top off each tire.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
Snomas
Denver, CO
I use a Pancake 150psi 120v and take it with me in the toad on long trips. Have had to use it several times.
2002 DutchStar 350 Cummins/Spartan Chassis, 2012 Ford Explorer
wny_pat
Western NYS
I use a Alcoa Wheel Straight-on 180° reverse service gauge. And for air, I use the engine's air compressor. My coach came with a air on/off valve, air hose and chuck which is connected to the coach's air system. I believe if Tiffin didn't offer one, that you can add one on yourself, or have a shop do it. There isn't much sense in hauling around a air compressor when you already have a on board, engine operated, air compressor.
Raymon
Phoenixville, PA
ATOMICPUNK wrote: Hi, I have a 2012 Allegro RED38QBA. I am new to the MH world. What tire pressure gauge and portable air compressor do you all use?
thanks,
Carl
So much for posting a question and not following up. Oh well; we did the best we could.
Ray
2inAlabama
Huntsville, AL
You should have an air port somewhere near the front of your coach. Mine is in the bay under the driver-side window. With the engine running and your air gauges at max, just plug your line in and air them up. I did have to buy a style A male fitting. The female fitting will be stamped with the style. Good luck
Just DH & DW
ATOMICPUNK
Raymon wrote: ATOMICPUNK wrote: Hi, I have a 2012 Allegro RED38QBA. I am new to the MH world. What tire pressure gauge and portable air compressor do you all use?
thanks,
Carl
Ray
thx for the info
Big Pig Racing
2012 Allegro Red 38QBA
ATOMICPUNK
As for the onboard air compressor, the tech at my dealer said it woould take a long time to inflate the tires with it. Looks like i`ll order a pancake compressor
bluwtr49
Green Valley, AZ
ATOMICPUNK wrote: As for the onboard air compressor, the tech at my dealer said it woould take a long time to inflate the tires with it. Looks like i`ll order a pancake compressor
He was probably talking about inflating from 0 not the normal use of simply topping off tires when the pressure drops due to temp change......big differance. A class A is not like an off road vehicle where you drop the tire pressures for traction and than need to go up from 15 psi to whatever. Also, I suspect that you'll seldom, if ever, need to add more than 5-15 psi on the road.
My 12VDC portable, for example, will add 7 psi to our 22.5" tires in less than 2 minutes. (95 to 105 psi). Also, it takes up minimal room and can be tossed in the toad if need be. When the Jeep is used off road, I can inflate the tires from 15 to 36 psi in ~3 minutes each.
DannyLeininger
TX USA
roam1 wrote: Sears makes(sells) a nice 110v unit
Think there was a thread a while back, maybe you could find it with search
I too use a Sears 120v Oilless Compressor that can pump 150psi. It works well and I've had it for years.
I would purchase a tire gauge from a truck stop. Don't cheap out, get a good one.
Danny Leininger
2007 Newmar Mountain Aire 4523
450 HP Cummins ISM on a Spartan K2 Chassis
2010 Explorer Eddie Bauer 4x4, nice
Good Sams, FMCA, Newmar Kountry Klub, AARP....
jocat54
Leakey, Texas
thanks,
Carl
Ray
Kind of fast for a blast on the OP....not everyone stays on the computer all the time.
I too use the the Porter Cable pancake (150 psi)works well for airing my tires to 110 psi.
"All it takes for evil to succeed is for good men to do nothing"
John & Kathy & Gizmo (maltipoo)
1999 38ft Monaco Diplomat DP
Leakey, Tx (Texas Hill Country)
