RV.Net Open Roads Forum: Fifth-Wheels: Trailer tires
 > Trailer tires
Splashers3
Oakville, MD
Posted: 08/16/12 03:35am Link  |  Quote  |  Print  |  Notify Moderator
I UPGRADED to LT to improve the longevity/durability/peace of mind - which leads to better sleeping at night. I got rid of my CHINA BOMBS with only 3000 miles on them.
I knew it wouldn't take Fast Eagle long to chime in.
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
CapriRacer
Somewhere in the US
Posted: 08/16/12 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Chuck&Gail wrote:
The DOT code tells you when and where tires were manufactured. All you need is the secret decoder ring. If you tell us the DOT code, we can answer.
Decode the DOT Code
CapriRacer
Visit my web site: www.BarrysTireTech.com
tvman44
Southwest Louisiana
Posted: 08/16/12 05:00am Link  |  Quote  |  Print  |  Notify Moderator
I did it to get away from the under performing cheap chinese trash tires.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
edatlanta
Panama City Beach, FL
Posted: 08/16/12 05:14am Link  |  Quote  |  Print  |  Notify Moderator
I have to agree with FastEagle. Why do some call every modification to their trailer/truck an upgrade when really it is a modification. It may be an actual upgrade or maybe not. "Upgrading" to tires with a lower weight rating in my mind is a modification, not an upgrade. Maybe this modification will work for some, but in my case it would be a downgrade since I have 7,000 axles and LT tires would definitely not work for me due to their decreased weight rating from the original ST tires.
My "upgrade" will be to G614's this next spring and I do have 110 psi wheels already.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
machunt
cincinnati ohio
Posted: 08/16/12 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Everyone has there opinion and are entitled to it. In my case i didnt trust the tow max tires i had. I went with Duarvis 250 for the steel casing.
Fire Instructor
Upstate (Albany) NY Area
Posted: 08/16/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
So by getting rid of my ST Carlisle"s, and going to Kumho 857's with a slightly better weight rating, and a MUCH better speed rating, was that a modification or an upgrade?
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
jetboater454
Camping or home
Posted: 08/16/12 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Another thing into the fray.
Peace of mind.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
joelc
Milford, PA
Posted: 08/16/12 06:35am Link  |  Quote  |  Print  |  Notify Moderator
popjim wrote:
And exactly what are the junk tires? or china bombs as you call them?? what make and model tires???
Duro is one that I know of.
JIMNLIN
out here
Posted: 08/16/12 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Norskeman wrote:
Trailer tires are rated for 65 mph. Those that upgraded to truck tires did you do it to improve the speed rating or load rating?
I have 16 inch load range E tires on the fifth wheel.
IMO it make no sense/cents using a inferior tire even with 500 lbs more capacity if the tire is unreliable.
I made the switch simply to gain reliability as ST tires simply didn't work for me. I tried going up in load ranges/next size larger/etc but still had the same results and these were all USA made major branded ST tires, many years before ST tire production were sent to overseas. Its amusing listening to china trailer tires getting bashed when we had the same issues when all ST tires were made in the USA.
Others have differeing experiences.
'97 Park Avanue 28' 5er 11200 gvwr two slides
tjar66
Camarillo CA
Posted: 08/16/12 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I reality there are lots of LT tires made in China. The Toyos on my TV say made in china right on them. The issue is that tires that a put on our cars and truck go through more extensive and stringent testing to get that DOT approval than ST tires do. We put LT tires on our rig when the ST tires started separating.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
 > Trailer tires
