RV.Net Open Roads Forum: Class A Motorhomes: shaky mh
 > shaky mh
kansanforlife
paola ks
Posted: 08/16/12 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Morning. I have a 1996 itasca suncruiser 38ft with hwh levelers. All jacks are down solid, but ihave a noticeable vibration when walking in mh. It does have 4 air bags, small, on the rear that i assume are for road leveling. theres nothing in my manual about them. There is a red low air light on dash but has never lit up. RV tech told me it would do no good to put any stabilizers on it. What could be wrong with it?
1995brave
San Antonio, TX
Posted: 08/16/12 09:25am Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing this is diesel. Dump the air in the bags and then try leveling. Remember do not let the rear tires come off the ground.
kansanforlife
paola ks
Posted: 08/16/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Its a gasser but might work on same principle. Im going to try it.
wny_pat
Western NYS
Posted: 08/16/12 10:39am Link  |  Quote  |  Print  |  Notify Moderator
kansanforlife wrote:
1996 itasca suncruiser 38ft........It does have 4 air bags, small, on the rear that i assume are for road leveling. theres nothing in my manual about them............... There is a red low air light on dash but has never lit up.
Sounds like something aftermarket that someone added to hopefully make it ride better. If there is air in them when you level, I can see where the coach might maybe shake.
How do you check the air in the bags and how much air psi are you suppose to run in them? Think if I were you I'd be checking around to find out just what kind of air bags they are and how they should be used.
kansanforlife
paola ks
Posted: 08/16/12 11:08am Link  |  Quote  |  Print  |  Notify Moderator
When i turn on the ignition key you can hear the compressor running for a few min. I turned the valve and it was stopped up so cleaned out valve and let air out. You could hear mh settling down. Releveled mh but dw not home to walk across floor. I myself cant feel it moving.
11Southie
San Diego
Posted: 08/16/12 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Try to lessen the throwout on the levelers. If they extend too far, they become less "solid" and the coach can have some movement. An easy fix are some 4x4 wood blocks under each jack. They also sell some stackable kind at WalMarts and such. Should help.
RLS7201
Some Where
Posted: 08/16/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
You have one of those rare Itasca/Winnebago gas motorhomes with the factory optional air ride on the rear axle. The air bags should deflate when parked and the jacks down.
Richard
Lt46
Central Florida
Posted: 08/16/12 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
kansas, I feel the jiggle too. My air bags do not deflate completly when the jacks go down. There is some air release (can hear it) but once the jacks level me out the the air leak sound has stopped. Now, over time, the bags will go completely flat (3-4 days).
Agree with the other poster about the 12 x 12 blocks under each jack. The less shiny ram showing seems to settle the jiggle a bit. It is never gone though. I attribute the jiggle to the extra long overhang on the chassis. With the rear jacks at the duallies, there is nothing suppoting the remaining 8' of moho. In fact, I've considered using a bottle jack or jack stand at the rear bumper to see if that takes some of the jiggle out. Someday I'll experiment with that.
Peter & Dawn
97 Winnebago Adventurer 37RW
96 Prowler 27X SOLD
IAFF L-792
kansanforlife
paola ks
Posted: 08/17/12 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Ive been toying with it for awhile now. Tried others advice and it has helped out. I do have a tag axle so no overhang problems. Its really not to bad just annoying to me.
 > shaky mh
