tboss
FLORIDA
ACRYL PRO is an execelent glue for attaching the ridged foam to the luan in the walls of your camper if you need to do repair.. its made to attach ceremic tile in the bath of you house,, it will not melt the foam,, its water proof and whn dry its there to stay...I got mine at Lowes...I used a 3/32 notched trowel to apply it ..
Joy
Henderson KY 42420
Did you maybe mean "rigid foam"?
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
tboss
FLORIDA
I didnt realise correct spelling was an issue here on this forum,,I thot as long as the info was understood and it helped someone with a problem then dat was wht was improtant....maby I have been wrong all these years....sorry I will try to do better...
ksg5000
Oregon
Thanks for the info -- will bookmark this thread.
Kevin
rehoppe
Denver & Nathrop Colo or somewhere else
tboss
Spelling doesn't seem to be an issue here. But rigid, and ridged are two different words. Had me scratching my head for a moment.
Don't be mad. LOL It's all good.
Or as they used to say at work. 'Don't worry, be Hoppe'
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
Lady Fitzgerald
Tempe, AZ, USA, Earth
The only thing I find more amazing than the number of people in this country who can't spell (and use proper punctuation) is the number who don't care or who think it's not important.
However, I do appreciate the tip.
Post edit: I just did a search on the stuff and found reviews ranging from profane to glowing. The only two videos I bothered with were by guys that sounded as dumb as moose snot. Most of the glowing reports sounded phony as a four dollar bill. The negative reports stated it was slow to cure or would re-emulsify if exposed to moisture.
Methinks I will stick (pardon the pun) to approved foam adhesives.
edited 08/18/12 08:08am by Lady Fitzgerald *
Jeannie
tboss
FLORIDA
Lady Fitzgerald,, I will do a water test on the pieces I have glued up and get back with you...
