RV.Net Open Roads Forum: What have you fixed or replaced in the last 30 Days
 > What have you fixed or replaced in the last 30 Days
Page of 6
joeprinter
Fayetteville, NC
Posted: 08/17/12 06:03am Link  |  Quote  |  Print  |  Notify Moderator
I for one have replaced a O2/LPG detector with the auto gas shutoff.
(would squeal all hours of the night, indicated lights showing malfunction)
Also a Dometic 310 Toilet (foot pedal broke, inside mechanism not servicable)
Front Electric Shade Motor (still in route)
(Motor wires twisted an tore to close to motor housing unrepairable)
Light bulb in Microwave (burt bulb)
All 3 weeks after Manufacture Warranty
I know the bulb wasnt covered, was surprised my Extended service plan doesnt cover the monitor.
When it rains it pours.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 08/17/12 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I'm still working on my unsual Norcold 1200 LRIM problem (it's been going on for over a year). Then, I have to get back to fixing the roof.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
RoyB
King George, VA
Posted: 08/17/12 06:15am Link  |  Quote  |  Print  |  Notify Moderator
I've been laying under my OFF-ROAD 14RT trailer re-routing my PVC 3/4-conduit to a better location to keep the underbrush from trying to drag this section of PVC conduit off when I am back off the beaten path with my POPUP trailer. Thought I had the PVC conduit in a good spot but noticed underbrush found it again. Won't find it now as I have it buttoned down up against the POPUP underside flooring running next to the trailer frame getting from point A to point B...
As usual when you mess with something already installed the cables end up being TOO SHORT. I had to rip out the cable and make it about a foot longer to fit the new re-route. This particular PVC Conduit houses my battery bank DC VOLTAGE and DC CURRENT wiring to my meter panel inside the POPUP.
We had a couple of cooler days here so was fun doing some under the trailer maintenance things.
My next bigger project is mounting some take down antenna support tower sections for my emergency radio communications I play with for RACES-SKYWARN-MARS RADIO. I need to get up above the ground about 15-feet after I setup my trailer in the woods or on a mountain trail off a forest service road and just came up with some small lightweight 4-inch triangle aluminum tower sections that I can hopefully figure out a way to carry either under the trailer or across the bumper or even down the side of the trailer along the long frame section. Will need to mount on top of the bumper and snap in place to the side of the roof to get it up in the air about 15-feet. Being portable I will probably use web straps to go down to some 18-inch long earth augers anchors with a 3-inch blade. Then I can use this for the center fed HAM RADIO long wire dipole antenna I need to give me more local distance coverage for my HF radio. Always something to play with...
* This post was edited 08/17/12 06:26am by RoyB *
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
swebber
Brunswick , MD
Thetford Aqua toilet
Four Goodyear Marathons
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
pasusan
PA
Posted: 08/17/12 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Replaced my water pump. Thankfully under warranty, but I did the work.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
gbopp
The Keystone State
Posted: 08/17/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Our 96 Southwind is in the shop having the rubber pads between the tag axle and frame replaced. They rotted away.
hallock5
Posted: 08/17/12 06:32am Link  |  Quote  |  Print  |  Notify Moderator
4 tires, upgrading to Load Range E.
Defrosted freezer.
AC filter.
Brake wiring was taped that separated, now butt-sleeved properly.
Seeking parts to replace Wineguard antenna's plastic crank % assembly.
10 hrs of hand washing/waxing.
My goal: Have 80% of your rig working properly 100% of the time.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
Raymon
Phoenixville, PA
Posted: 08/17/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Replaced an IOTA automatic transfer switch. Replaced 2 cables on the BAL Accu-Slide slide out; not an easy job. Installed a "stop" on the sliding bedroom door to prevent the second door (back door) from sliding too far if MH is not level.
I never had soooo much fun until I bought my RV's; always something to fix or modify. Just glad I am retired.
Ray
keatonb16
New Brunswick Canada
Posted: 08/17/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
I was under my pop up greasing the lift system and noticed my ground wire from the converter had broke away from the frame. new screw quick fix. guess I haven't been grounded all summer
2007 flagstaff 208
2010 Rav4 V6
JRS & B
Florida/Michigan
Posted: 08/17/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
If I ever run out of things to do, I can always go around and check the cupboard doors. There always seems to be at least one that has come loose. Eventually the holes for every hinge will be "refilled" with toothpicks and wood glue. As a side job I change burned out light bulbs and clan A/c filters.
Page of 6
