RV.Net Open Roads Forum: What have you fixed or replaced in the last 30 Days
 > What have you fixed or replaced in the last 30 Days
Page of 6
CR CRUISER
Campbell River,BC
Posted: 08/18/12 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I ripped out the piece of junk, Xantrex HF 1800 watt inverter/charger and replaced it with a Magnum MS pure sine wave 2000 watt. The new one was almost triple the cost of the Xantrex but it is infinitely a better unit.
tomkaren13
West Central Florida
Posted: 08/18/12 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
The Travel Travel itself was replaced. Would not spend the money to replace the roof. Traded for a small 5th.
conmoto
Northern Illinois
Posted: 08/18/12 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
We replaced the Norcold with a Samsung. It has been very good so far!
bigred1cav
ohio
What are inverters used for? I have a generator what would an inverter do the gen won't?
Wouldn't an inverter run the batteries down very quickly?
Handbasket
Asheville, NC
Posted: 08/18/12 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
A little more than 30 days ago, the Onan Microlite 2800 started surging drastically and then stalling. Took the fuel line off the carb, and found it dry. Ended up DIY replacing the fuel pump, which involved pulling the Onan out of its compartment to get the top cover off. PITA for one old man in hot weather.... but fixed it. Ran fine for about 10 hours.
Then about two weeks ago, the voltage started varying from normal to low (~80, sometimes into the 70's) with no change in engine RPM unless volts went really low, which made the engine stall. DIY diagnosed a failing voltage regulator, and replaced it with a Flight Systems unit. Minor PITA, $240. Runs fine now.
(Notes for DIY'ers with 2800's... the voltage regulator on these lives (and dies) under the cylinder head, not behind the control panel as per some on-line sources. One screw, a #25 Torx; major PITA getting it back into the hole (can't see it).)
Jim, "Europeans think 100 miles is a long way. Americans think 100 years is a long time."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Navy Smoker
Northern Maryland
Posted: 08/18/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
The Norcold reffer so that it would run on propane.
timc1207
Posted: 08/18/12 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Been on 4 trips in the last 5 months and I've had to fix uhm well, Hmmm I think it was ... Nope haven't had to repir a thing.
2008 Forest River Wildwood Le 27BHBS - 2010 Dodge 2500 Laramie Mega cab 6.7L Cummins diesel, Flo-Pro exhaust, XRT Pro tuner, Mygig Lock Pick, Access tonneau cover, Ranch Hand grill guard, KC daylighters.
campn4walleye
Central WI
Posted: 08/18/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
I'm almost afraid to say it aloud as it might jinx us...but we have the Dometic fridge working again...FINALLY! It was like herding cats getting the warranty work done without going through the dealer.
DH diagnosed the problem and we contacted Adventurer and Dometic to get them to send the part directly to us so that we wouldn't have to wait on the dealer's back log.
They sent us 2 new thermalfuse assemblys. DH installed it and it's working great!
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
travelnutz
West Michigan - On the Lakeshore
Posted: 08/18/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced? Oh'ya, I dumped the holding tanks and replaced the holding tank chemical that was dumped. Does that count?
That's all!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
trailerbikecamper
eastern Canada
Posted: 08/19/12 03:10am Link  |  Quote  |  Print  |  Notify Moderator
I have replaced some of the caulking around the seals where one section of siding joins another section. I replaced a light switch on one of the reading lights. A tire blew on the way home last week. I replced both rain gutter spouts at the front with extensions to help reduce the black streaks.
Trying to get a beauty (trim) ring for the rim where the tire blew.
Dan/Mary
Page of 6
