The unit just arrived and the only instruction I've found is on the cannister. It simply says to take off the cap and add salt. Okay, but the gold powder is right there. Do I take it out? Looks pretty easy to spill. There's sure no room to pour salt over it. The company web site is no help.
Should I wait until I'm ready to hook the unit up to add salt?
Do I add salt right out of the box, or make a salt solution? If so, how much water?
Is there any indication regeneration is due, or just estimate water usage?
Any information will help. Thanks.
'11 Eagle 320RLDS
Equalizer WDH
'02 Ford F350 dually, unchipped 7.3 PSD, PacBrake,
6.0 cooler, Ford AIS and Isspro trans. gauge
Replaced old AirLift airbags
The Flow-Pur and On-The-Go water softeners are basically the same units. Both 'soften' water using resin beads that attract the minerals to them and then when they are 'coated' you regenerate them (clean them off) using table salt.
Should have been an instruction sheet covering 'operation' and 'regeneration' included in box........dumb.
How do I regenerate my Mark 8000?
To regenerate your Mark 8000, you simply dissolve a box of common table salt in some water, unscrew the large cap on top of the softener head revealing the large opening and pour in the salt water solution. Let it stand for 30 minutes. After the 30 minutes is up, flush the unit for a few minutes to remove the salt water. Reconnect the water supply to your RV and you are ready for several more weeks of soft water.
And this:
Approximately how long will my softener work before I need to regenerate it?
That depends on the condition of the water that you are treating. The Mark 8000 has the capacity to remove 8000 grains of hardness. If your water source is 10 grains hard, then you can treat 800 gallons. If your water is 5 grains hard, you will be able to treat 1600 gallons. This is why we did not place a meter on the Mark 8000. Water softening is a function of hardness not metered gallons. Hardness test strips are easy and convenient to use to determine if regeneration is necessary.
We use a softener when in AZ, NM, TX and anywhere that the water source is hard. 2 adults..FT-----I regen every 2 weeks. They have test strips but I just make it a routine vs testing water.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Thanks, O-B, I double checked the box for instruction booklet, Nothing. You say remove the top. I unscrewed it and the resins are right up there level with the top. I'm wondering if they can be pushed down into the container, although it looks like they may be sitting in a cup. As I said, "It simply says to take off the cap and add salt. Okay, but the gold powder is right there. Do I take it out? Looks pretty easy to spill. There's sure no room to pour salt over it."
I'd hate to go punching around and mess it up before I ever get it off the work bench. I'll email the company and request the instructions.
So I pour the slurry slowly over the resin pictured in the link? Sorry to be slow, but it doesn't look like a good plan and the "instructions" would appear to say, yes, don't worry about the resin. Pour here?
edited 08/18/12 08:45am by cekkk *
Yeah, don't use it often enough to get it right every time, got to work on that in Forum Tech Support.
But, question answered. I called Flow Pur this morning and the answer is simple - It's ready to go! No need to add salt until the test strips, which I found, indicate the need.
Then, and I don't see this instruction anywhere, but CS said to blow out the amount of water to be replaced with the slurry, then remove the top and pour the slurry over the resin.
Been using the Mark8000 for a couple of years. You should not be able to see the gold powder when removing the cap. My guess is you haven't used the 8000 yet. I think you should remove the cap, then there is a strainer thing that can be removed, remove it and pour the gold powder into the 8000.
When it's time to regenerate what I do is unhook and cap the input connector to the 8000. Remove the output side hose but do not cap it. Remove the 8000 cap and the strainer and begin pouring salt into the 8000. I use the supply water hose to trickle water into the opening to help get the salt into the belly of the 8000. By leaving the output side of the 8000 open will allow a small amount of water to escape and make room for the water you are adding to get the salt into the 8000. Once all the salt has been input replace the strainer and top, and cap the output side of the 8000.
Every 10 minutes I will shake/invert the 8000 to help mix the salt. After about an hour I hook up the supply water hose to the 8000 and attach a short hose to the output of the 8000 and run water through the 8000 for about 3 minutes. I then remove the short output hose and re-attach my hose from the coach.
FWIW, I did replace the gold resin in the 8000 after 2 years as it didn't seem to be working. IIRC it was about $25 for the replacement resin, 3 gallon jugs of dry gold resin.
