Fifty4F100
Bartlett
I know I've heard this isn't a good idea, but what kind of trouble would I be in if I backed our Jeep Liberty onto a tow dolly? I think I've found a dolly maker that suggests just this:
http://americancardolly.com/Useful%20Tips.htm
Glenn in TN
04 Liberty daughters
03 Mazda 6 wish I could tow it
00 Ford Taurus wish I could tow it 4 wheels down
99 Holiday Rambler Vacationer w/05 PT Cruiser toad
gbopp
The Keystone State
Clicky
past-MIdirector
Michigan
Is it safe if done right according to the manufacture of the dolly by adding weight to the vehicle to counted the front weight. What does your Jeep manual say about towing it this way? A lot of today's manufacture only recommend a certain distance a vehicle can be towed this way.
mowermech
Billings, MT
In the Owners Manual for the '06 Liberty we used to have, (and in the book for my '06 Rubicon), dolly towing is strictly forbidden.
Of course, both of these were/are 4X4 vehicles. If you have a 4X2 Liberty, then you could back it on the dolly.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Fifty4F100
Bartlett
mowermech wrote: In the Owners Manual for the '06 Liberty we used to have, (and in the book for my '06 Rubicon), dolly towing is strictly forbidden.
It is a 2wd.
jauguston
Bellingham, WA
You could have some instability towing backward. The steering geometry has caster and camber that is designed to keep the vehicle steering stable going forward. Its all wrong going backward.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
johntank
Oxford, Ms 38655 USA
Since it is a 2WD towing backward can be done going by the link provided above, the only thing I can think of is one would need a good system of tieing the stearing wheel to prevent any movement. The only other thing is you might get some inside tire wear by towing it backwards.
camperkids1025
Bel Air, MD.
It's not worth the risks, trouble and worries not saying the liability.. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
mowermech
Billings, MT
camperkids1025 wrote: It's not worth the risks, trouble and worries not saying the liability.. Jim
OK, that is YOUR opinion.
Some folks do not agree.
Enough said.
tahiti16
Camarillo, CA
Some vehicles seem to do better than others, there have been several people on here that have successfully towed backwards 100's of miles with no issue. One key to that is the steering is secured straight ahead and do NOT rely on the steering lock as it was not designed for that and if it fails the results could be ugly to deadly.
If you have access to a dolly I would suggest trying it in a parking lot to start with and move out onto empty streets like an industrial park on the weekend to check out the setup.
Also plan on stopping several times over the first hundred miles to check that everything is secure until you are sure it works in your setup.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
