I caulked mine shut also. Rain whipped sideways by the wind or dripping from the immovable gutter above would fill the track and find it's way in. The windows don't open now but so what...I never used them anyway.
Eric
1999 24' Fleetwood Jamboree E350 towing a 2007 Hyundai Elantra
I have been thinking of sealing our side windows shut also, is there a chance someone could post some pics showing how you did it, along with some explanation on just how,& what you used??? Thank you in advance!!!
Duckaholic1 wrote: I have been thinking of sealing our side windows shut also, is there a chance someone could post some pics showing how you did it, along with some explanation on just how,& what you used??? Thank you in advance!!!
Sorry, no pics, but it's really nothing tough. The small window slides back and forth in an aluminum channel and I just cleaned that channel out well and put a goodly sized bead of clear silicone caulk in there paying close attention to the bottom edge of the window effectively not allowing any water to enter that channel and seep in sideways through where the window is. The silicone never sticks all that well so it will be removable later if I care to but if I don't disturb it, water will continue to run off of it away from the window. At least it has so far.
Ok, thanks for the reply!! I'm in the process of sealing the tops & sides of our windows. I think I'll give it a try when I get to those windows!! Happy Campin' to ya!!!!
If the window tracks are leaking, try this.... The sliding side windows are supposed to drain down into the frame to the weep holes. They know they can't keep the sliding mechanism from seeping.
My Hehr windows have a lower track. Water is supposed to get into it and follow along it to whichever end is lower, then drop thru a small space at the end, thence to the weep holes. If your lower track has shifted to front or rear, this space may be closed up at that end. Just wedge a small screwdriver into the gap, and twist gently.
Jim, "Out of my mind... leave a message and I'll get back to you."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Handbasket wrote: If the window tracks are leaking, try this.... The sliding side windows are supposed to drain down into the frame to the weep holes. They know they can't keep the sliding mechanism from seeping.
To the OP. Before you start replacing and sealing up stuff try what the above forum member suggested!!
I had a bad leak from the window above the sink that seemed to be coming from the track too and was just about to seal it shut with silicone I was so angry! I took a look at those weep holes like he suggests and dang his advice is right on!
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
