RV.Net Open Roads Forum: Tech Issues: Oven Burner will not light
 > Oven Burner will not light
jmangrum
western ky
Posted: 08/18/12 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I have a friend who has a new to him 80's Class C and is having problems with the oven. The pilot will light just fine but the Burner won't light at all. It has what i call a sensor type wire running from the oven control knob with a thermocouple type end on it down to the pilot light. I cleaned that with no results. I don't think the valve in the control knob is getting the signal to open and send gas to the burner. I think the control knob is faulty. Any ideas ? Sorry i don't remember the make of the stove but thanks in advance for our help. Jeff
1978 Travel Queen 27' class a
440 cid gas 727 tranny
62,000 miles Dodge M-500 chassis
onan 4.0 kW
Family of four and pepper the poodle
motor home pic http://www.flickr.com/photos/j_man46/
Go Dogs
South of Pittsburgh, PA
Posted: 08/18/12 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Could it be the propane tanks are empty?
jmangrum
western ky
Posted: 08/18/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
No the Stove Burners all light and we lit the frig and water heater. THANKS
past-MIdirector
Michigan
Make sure when you turn the oven thermostat up to around 300 that the pilot flame gets large and engulfs the thermocouple. The thermocouple on the pilot burners needs to get red hot, usually a minute or two for the safety valve to open for gas to flow to the burner. If the pilot flames does not get larger than the pilot burner is bad or oven thermostat is bad, if the flame get larger and the thermocouple get red hot and the safety valve does not open then the safety valve is bad.
jmangrum
western ky
Posted: 08/18/12 09:18am Link  |  Quote  |  Print  |  Notify Moderator
That is what i noticed. The pilot flame does NOT get Larger. So what do you suggest ?
past-MIdirector
Michigan
Posted: 08/18/12 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Take the pilot burner out and clean it with a wire brush and make sure no bug has made a nest in the burner tubing. Put the pilot burner back in and try again. If the flame does not increase to engulf the thermocouple than the oven thermostat is bad. You can try removing the oven thermostat and taking it to an large Appliance Parts store and see if they can match it up.
jmangrum
western ky
Posted: 08/18/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
I cleaned the pilot burner and it didn't help. I will try and replace the thermostat. Thanks Jeff
