Our GS has a 2000 Ford 150. He has a gringing metal sound comming from the rear axle. He Jacked it up and turned the tires manually and said it was really Bad. This is his first Vehicle which I bought him a year ago. Any Idea's will be appreciated.
Harold and Faye US Navy Retired
2006 Fleetwood Revolution 40LE
400 cat
Differential, could be wheel bearing, carrier bearing, or inner or outer pinion bearing. Badly fractured spider gears, or huge chunks missing off the ring or pinion can make the noise as well. A U-joint that makes a grinding noise will usually be findable without dropping the driveshaft.
i have seen a number of 8.8 axles with the wheel bearing at the end of the rear axle shaft failed. also the rear safety brake shoes come apart and make a bunch of noise at times.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
