turbopilot51
Ridgefield, WA
Yesterday to my dismay I found the rear driver's side tire completely flat on my Alpine 3500re. I thought about changing it out myself but notice that the spare tire is not mounted on an aluminum wheel like the others. So I aired up the flat tire and made a bee line to the closest tire shop. Les Schwab in Battle Ground Washington removed the flat tire and mounted the new spare on the aluminum wheel. Then they mounted the fixed tire on the spare rim and even mounted the spare under the fiver. You can imagine my surprise when I was told there was no charge! I told the assistant manager that I would bring my rv back for new tires when the time comes.
coolbreeze01
Redding, Ca
Excellent service from them here too.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
trucker495
Linden, CA
I too have had stellar service from Schwab!
04 HR ALUMASCAPE 31' TRAVEL TRAILER
05 RAM 3500 4X4 CTD SRW CREW CAB LONGBED
amandasgramma
Oregon
We refuse to go anywhere else!!!! My folks won't go to LS -- instead they use another "big name" tire dealer. When she had a flat, within sight of the LS store, she called the other "big name" tire dealer. It took them an HOUR to come help her out (and they're less than 2 miles from where she was) and then they charged her $25.00 for fixing her tire and $25.00 for coming to help her. LS doesn't do that!!!
LBL 1206
Land Between the Lakes, TN
Yep! Les Schwab in my hometown of Walla Walla has been on top since I was in high school. They still provide outstanding customer service.
ronniedean1234
Washington State
Les Schwab #1 for me also , best service of any dealear in town. Happy Campin..........Ron
2012 Montana 3800RE/Level Up/Slide Toppers/MoRyde Hitch/VuCube 2000
1999 Freightliner Western Hauler CC/300 Cat/Chipped
2001 Ford F350 CC DRW/ 4x4/ 6 Speed/Chipped
djgarcia
Northern, Ca. , USA
Les Schwab in Chico California is totally outstanding!!!!!!
Dick
djgarcia3@att.net
old guy
Oregon (pronounced Or e gun)
I've had an account with them since I was in High School. That was over 50 yeas ago. I was one of their first customers back then. we are on first name bases. they have saved me lots of money over the years.
Valkyriebush
Yuma/Port Townsend
I agree, They are one of the best companies for customer service in this country. Had a squeeling disc brake and it was only a rock stuck in the caliper. NO Charge! They even greeted me in the parking lot as I drove in! Only wish they weren't in a limited area of the US.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
h2guy
Ain't seen a sign yet!
Had a slow leak in LR outside dually in Columbia Falls MT. Went into the LS store there and tech sez small screw in middle of tread. Plugged/patched it, mounted it, $17, and off I go
Airway Heights WA, I got a slow leak again, same tire. Go into LS store there, they say leaking valve stem, install a metal chrome stem, no charge, off I go.
Month now, no leaks. Happy Camper.
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
