Mocoondo
Chicago, IL
I wouldn't worry about the scratches.
It would have been a very good idea to thoroughly clean the area before you applied the Eternabond. If you didn't clean beforehand, don't be surprised if it starts to peel up over time and will need to be re-installed.
paullac
Cincinnati, OH
Just curious - Did the dealer comment on the bubbles?
'13 Forest River Sunseeker 3100
'04 Fleetwood Sedona / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar
bondebond
Searcy, AR
Hopefully there was no moisture from rain or washing before you sealed it up. Those bubbles look like the kind of thing that happens when water also gets involved. If there was moisture in there, it's now trapped. Rot can ensue.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
atvaholic
Niagara Falls
bondebond wrote: Hopefully there was no moisture from rain or washing before you sealed it up. Those bubbles look like the kind of thing that happens when water also gets involved. If there was moisture in there, it's now trapped. Rot can ensue.
Hmmm, this has got me thinking now. I felt inside the tear with my fingers and it was perfectly dry. You are thinking the bubbles are due to water being inside the roof?
bondebond
Searcy, AR
That is my opinion...that water got inside at one point. If it's not too late, I would try to work the bubbles out, although I am sure the adhesive underneath won't re-bond now.
I'm glad it was dry inside. That's a good thing. Hopefully that was the extent of it. I would keep an eye on it and check inside on the ceilings, especially at the low ends of the roof edges.
Kalabin
Alaska
Bubbles on the roof would be because the adhesive is failing in that area. The way these rubber roofs are laid down is the following.
1) Sheet of plywood
2) Sheet of Luan Decking is glued to the plywood (this is used to sand down for a smooth surface for the rubber roof to adhere too.
3) Rubber / TPO roof is glued down to the Luan Decking
When they put the rubber roof down they put a bunch of adhesive down on the luan then they smooth out the roof on it with a squidgy. This spreads the adhesive across the rubber roof which is why there is no bubbles typically. I was told there is always a chance near the edges that bubbles may show where the roof folds over the edge and the trim piece covers the transition from roof to side walls.
This is how it was explained to me from the shop that recently replaced my entire roof from damage.
2008 Chevrolet Silverado 2500HD 6.0, 3.73, Firestone Air Bags, CCSB LTZ
Ron3rd
Upland, CA USA
Don't know if this is correct or not, but I read once that the roof is not glued down in the middle, only at the edges. The only issue I see for the OP is whether there is any water damage under the membrane. Otherwise, the EB tape is basically a permanent repair. The quick patch job should be OK for his trip. If the EB peels up a bit, simply remove it and prep the area properly and reapply again per the EB instructions, meaning it has to be rolled down HARD to release the microsealant.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Mr.z
NC
I just purchased a used 2010 Wildood Sport toyhauler by Forest River, and while I was cleaning the roof I noticed a few bubbles in the membrane. Is this normal? I'm the second owner, so would this be covered under warranty? Even if I'm the 2nd owner? If it's not covered under warranty, should I fix this and how?
TURBODOG1000
INDY
The Eternabond should take care of your holes. Keep a watch on the bubbles and make sure that they don't grow. You should be good to go!
edited 08/23/12 08:16am by TURBODOG1000 *
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
Charlie D.
E. Texas-Orange
Ideally, 100% adherence is desired but not always practical. A few bubbles scattered around the roof is not uncommon and as AKJason said, the top just before the transition to the side will often have areas that are not adhered. My old camper had areas near the edge and side for 7 years and 40,000 miles without a problem.
Have the dealer inspect and document, get a copy of the inspection report because dealers often do not have a paper trail, for future reference.
If it helps you feel better, climb a few roofs at the dealer to see how other roofs look.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
