RV.Net Open Roads Forum: Tech Issues: PROPANE DETECTOR PROBLEMS
 > PROPANE DETECTOR PROBLEMS
patt4you
Posted: 08/19/12 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Everyone i have posted this before but still have the same problem. I have no propane leaks, i moved all cleaning supplies,and it still goes off. the battery shows strong too. NOW answer methis..it only goes off at night, never in the day. its always after midnight when all is turned off. no drain on battery or anything. I have to turn off the breaker for the dc power and unhook the hot battery cable. wait alittle and it works again....help me.
BillJ999
Home
Posted: 08/19/12 06:03am Link  |  Quote  |  Print  |  Notify Moderator
How old is the detector?
rbp111
Citrus Heights, CA
Posted: 08/19/12 06:06am Link  |  Quote  |  Print  |  Notify Moderator
It sounds as if your propane detector has gone bad. Mu unit went off at night or when the trailer was rolling. I changed it out, and it does not do it any more.
It is an easy fix and not too expensive (around $20).
patt4you
Posted: 08/19/12 07:05am Link  |  Quote  |  Print  |  Notify Moderator
The detector is 2 yrs old. this is a 2010 unit. If the detector is bad why does it only go off after midnight ??? looks like a bad detector would go off during the day also.
joelc
Milford, PA
Posted: 08/19/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
It would also be a CO2 detector perhaps. Are you running a generator or eating too much beans.
patt4you
Posted: 08/19/12 07:17am Link  |  Quote  |  Print  |  Notify Moderator
No NO it just seems weird
amandasgramma
Oregon
Posted: 08/19/12 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Ours will go off when the doors and windows are all closed up tight. The chemicals (fumes) in the paneling or plastics seem to set it off. We leave a vent open in the living room area and it doesn't go off.
Another thought --- Your rig may be 2 yrs old but the detector could be ancient.....manufacturers tend to buy in bulk and keep for years. For example, in our MH we found out the back up camera had been discontinued about 3 yrs before the rig was built.
johnrbd
San Joaquin Valley
Posted: 08/19/12 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Pull the detector out and check the date of back side.
patt4you
Posted: 08/19/12 10:00am Link  |  Quote  |  Print  |  Notify Moderator
THE DATE ON THE DETECTOR IS SEPT 2009. SAYS TO REPLACE IN 3014 THATS A LONG TIME I DONT BELEIVE THAT. I WILL TRY AN OPEN WINDOW.
ksg5000
Oregon
Posted: 08/19/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a dog? something as simple as your dog farting while sleeping next to the propane detector will set them off.
Kevin
