RV.Net Open Roads Forum: LED Lighting questions
mlh
Walker, Louisiana
Posted: 08/20/12 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I have a question or two about LED lighting. Here are some bulbs for sale on ebay that I am considering purchasing. LED Lights
Would these work with the standard 921 bulbs in an RV? It looks like the pins are on opposite sides of the bottom of the bulb. I have seen some that have them on the same side. Does that make a difference? I just want to make sure they will work before spending my money.
2010 Sunseeker 3170DS
2012 Ford Escape
Roadmaster Falcon 2 tow bar
1mtnman
Colorado
Posted: 08/20/12 11:28am Link  |  Quote  |  Print  |  Notify Moderator
They will work fine. I have several in my TT. They produce a white light that may not be desirable to some but for me they are fine.
tvman44
Southwest Louisiana
Posted: 08/20/12 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Should work fine, I have a couple on order, should be in any day now.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Lynnmor
Red Lion
Posted: 08/20/12 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
I think that you will find the output too little and too white.
KJINTF
Montana
Posted: 08/20/12 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a refelective bezel around the bulb?
Something to focus the light?
For less than $2.00 you can not go wrong
I have several of them - no issues
Thompson Falls Electronics
Always more projects than time
camperpaul
Wherever I park my travel trailer
Posted: 08/20/12 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at this 11 page thread:
My LEDs
Everything you ever wanted to know about LEDs and then some.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
anoldman
Middle Tennessee
Posted: 08/20/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I bought some of those eBay led lights, 36 panels and 48 panels. Neither was as bright as my old bulbs and neither lasted very long before the leds started failing. I went back to my old bulbs and forgot about the leds. Even at eBay prices they were nothing but a waste of money.
tenbear
Northern Vermont, USA
Posted: 08/20/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would advise you to buy a couple and see if you like them before you buy a whole bunch. Be aware that LEDs are polarity sensitive. If a light doesn't work turn the bulb over and it should light. I do think that 28 LEDs will not be as bright as a 921 bulb.
Many people do not like the white light, preferring warm white.
My experience has not been the same as anoldman's. I have converted almost all of my lights to LED and like them. The brightness and color are fine and the current drain is much lower than the incandescent bulbs they replaced. A few of mine have had 3 LEDs fail, out of 36. You can hardly notice the decrease in light output.
* This post was edited 08/20/12 08:59pm by tenbear *
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
JiminDenver
Denver, Co
Posted: 08/22/12 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I haven't tried those but did convert the whole rig over to leds and couldn't be happier. I agree that the ones you have chosen might be a bit dim. I used 48 LED panels and dimmer 9 LED cob style.
This is my thread with pictures to compare.
My thread
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
tvman44
Southwest Louisiana
Posted: 08/22/12 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I purchased a bunch of 48 LED bright white panels and when I install I will also install a #7812 voltage regulator for each fixture to limit the voltage to the panels as we always use park power and don't want the 14 volts from the converter to 12 volts to the LED panels. As soon as I can use my right hand again I intend to tackle this project in 3 or 4 fixtures and if satisfactory then I will do all of the fixtures. The reason for the delay is I had a accident and lost part of 2 fingers on my right hand and still have pins in one finger.
