RV.Net Open Roads Forum: Towing: Towing an Amerilite 24rk with 5.8l tahoe
Search only in Towing
Open Roads Forum  >  Towing
 > Towing an Amerilite 24rk with 5.8l tahoe
pennster
springfield missouri
Posted: 08/20/12 08:54pm Link  |  Print  |  Notify Moderator
We have a 1995 Chevy tahoe with a 7000 pound towing limit and a class 5 hitch. We are looking at the above trailer which has a 4200 dry weight. There will only be my wife and I camping. Is this a reasonable match for our towing vehicle? Most camping will be within a 200 mile range. Thanks for any help you can give us. Steve and D'Andrea.
JiminDenver
Denver, Co
Posted: 08/22/12 07:15am Link  |  Print  |  Notify Moderator
We tow a Amerilte 25bh with a dry weight of 4200 lbs with our 07 Expedition that doesn't have a tow package and is limited to 7000 lbs. We always tow in the Rockies and so far have had no issues.
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 800w inverter generator
pennster
Posted: 08/22/12 07:20am Link  |  Print  |  Notify Moderator
Thank you for your input. We are going to look at the trailer in the next two days. Steve
bartlettj
Forest Grove, OR
Posted: 08/22/12 01:35pm Link  |  Print  |  Notify Moderator
Shouldn't be a problem... I tow a Passport 235ML with my '03 Tahoe (5.3L 4x4) and it does just fine. My Passport has similar weight. Just make sure you install a transmission oil cooler if you don't already have one, the 4L60E transmission doesn't like to overheat.
pennster
Posted: 08/22/12 03:23pm Link  |  Print  |  Notify Moderator
Thanks for the reminder on the transmission cooler. Steve
eric james
Sioux Falls, SD
Posted: 08/22/12 03:57pm Link  |  Print  |  Notify Moderator
You'll be fine. 4600 dry is probably the most you'd want to go.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
