RV.Net Open Roads Forum: Long bed owners - how sharp can you turn?
 > Long bed owners - how sharp can you turn?
TriumphGuy
Simpsonville, SC, USA
Posted: 08/21/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Dumb question from a SB owner here ... I plan for my next truck to be a LB so I can do 90deg with my 5er and have more room for stuff, general hauling etc. Things have changed since I bought the SB and would rather have the room despite the truck length.
I've always thought that the LB would let me do a 90deg turn. True or not always?
2008 Crossroads Cruiser 32BL (Mack); 2000 Ford F250 Lariat 7.3 (Doreen); 2000 A4 Audi 1.8T Quattro (Lightning); 2006 Subaru Outback 2.5XT (Sally); Last but not least - one great wife and two beautiful kids.
Any opinions are my own and not of my employer.
jdulworth
Northern California
Posted: 08/21/12 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have an F450 (Only sold with long bed) I can turn way past 90 if needed... And I believe unless you have a very unusual trailer it would be true of all 5th wheels. I am using B&W Companion Hitch.
* This post was edited 08/21/12 02:27pm by jdulworth *
gwalter
Colorado
Posted: 08/21/12 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
I can also turn past 90 with by Ram 3500 using a B & W companion hitch.
2010 Ram 3500 Laramie
Elk Ridge 34QSRL
B & W Companion Hitch
nremtp143
Georgia
Posted: 08/21/12 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
I can turn past 90* with my F350 and B&W even with a low profile toolbox across the bed. Just has to be pretty level.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
rhagfo
Portland, OR
Posted: 08/21/12 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Well past 90 degrees, likely 95 or so, makes U turns a joy.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
Old-Biscuit
Across the USA
Posted: 08/21/12 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Longbed here.......easily turn 90* PLUS
Don't like doing it due to the extreme sideloading on FW tires/suspension so I avoid as much as possible which is 95% (or higher) of time.
Rather make a 3 (or 4,5,6) point turn vs sharp u-turn.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
dbbls
Missouri
Posted: 08/21/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Same here. My trailer came with a sticker on the front corners that said one could turn 88 degrees with a short bed truck. That seems like it would be enough for anyone. Trailers that are rounded in the front can turn shorter that ones that are flat across the front. Mine is very rounded.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
3 dog nights
Central, Virginia USA
Posted: 08/21/12 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't make it 90% as the pin box hit the rail caps. Just enough to take a chunk of the plastic, but not hit the metal. Didn't notice it at the time so don't know if I was level or not. As always....pay attention to everything!
Bob & Lynn
3 Hua's and Memories of the late, great Zoe, the camping Chow
2013 Open Range 424RLS, Hensley TS-3 Hitch
4-6v golf cart batteries & 2 Honda EU2000i
06' Chevy 3500, dually, crew, Duramax/Allison
the bear II
Torrance CA.
Posted: 08/21/12 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have a long beed pickup truck bed on my MDT. It will go past 90 degrees plus the MDT truck has a 53 degree wheel cut so u-turns are spectacular.
RVman3252
Ohio, USA
Posted: 08/21/12 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I can turn past 90 degrees, but as others stated it should be level and I do try to avoid turns that tight.
RVman / John
RVman3252
3252Px3 KZ Sportsmen Limited Triple Slide Fifth Wheel
Dodge Ram HD2500 V-10 Quad Cab 4x4 w/ PullRite Super 5th
Good Sam Life Member
