RV.Net Open Roads Forum: Hybrid Travel Trailers: Battery
Baidy
Walkerton On
Posted: 08/21/12 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the scenario. New battery in May. Last two nights camping the battery went completely dead over night. Was charged fully on the genny in the morning. Had the battery tested. Perfect battery. The only thing running was the fridge.Its usually about half charged everty morning when I run the genny. Looking for ideas to try.
rrupert
NW PA
Posted: 08/21/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you are running the fridge on 12 volts it will kill a battery in short order. How long did you run the generator? It takes a long time to bring a battery up to full charge.
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
skipnchar
Topeka or somewhere else
Posted: 08/21/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
When you say "completely charged in the morning" I assume you mean about 8 hours on the generator? That's about how long it would take to COMPLETELY charge your battery. IF you're using the generator 12 volt circuit to charge then make than 24 hours.
You ALSO need to be aware that if you have a Marine/RV battery it will only withstand two or three COMPLETE discharges and it'll be toast. Basically those are starting batteries and never meant to be completely discharged.
Good luck Skip
RoyB
King George, VA
Posted: 08/21/12 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on Skips comment - We always monitor our batteries to make sure they don't get down below the 50% charge state which is around 12.0VDC. I use smart-mode charging techniques here and can bring my batteries bank to their 90% charges state (12.5-6VDc) in as little as 2-3 hours of running my 2KW generator.
We planned it all out and are able to run almost everything we run at regular camp sites with electric service with the exception of the Air Conditioner and high wattage microwave. For us we use around 250-300WATTS between dark and 8AM the next morning when we re-charge again. My battery bank has around 250AHs capacity.
Works out for us pretty good camping off the power grid... It does take some pre-planning and also some beefing-up of the battery system. We found you cant just do one thing and be successful.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Baidy
Walkerton On
Posted: 08/21/12 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used it the same way for 8 years and the new battery since May.Its always worked perfectly until two days ago. So I don't think it has anything to do with the battery pack or the lengh of charge. Some thing is draining it. That's what I'm tryting to find out.
RoyB
King George, VA
Posted: 08/21/12 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
This is a typical drawing showing most of the 120VAC and 12VDC power distribution items. maybe you can start with each one of the items listed here especially connected to the 12VDC battery circuits and see if it is engaged... Might give you a clue on what to look for...
photo from google images
bikendan
Napa, Cal.
Posted: 08/21/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
hybrid trailer fridges don't run on 12v, only the electronics.
they are either 110v AC or propane.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
f150camper
WA State
Posted: 08/22/12 12:20am Link  |  Quote  |  Print  |  Notify Moderator
If you use 300W after dark, you would draw your batteries down to 50% in about 5 hours, and completely drain them in less then 10 hours, right?
Nights camped 2011: 13 (4 in the old popup)
Nights camped 2012: 36
Nights camped 2013: 2
2012 F-150 XLT screw 4x4 HD max tow
2012 Jayco X19H
RoyB
King George, VA
Posted: 08/22/12 03:51am Link  |  Quote  |  Print  |  Notify Moderator
Taco6spd - my biggest draw on the batteries is between 8PM and 11PM of course with all the lights and home entertainment center items. After that between 11PM and 8AM it is a nite light, motion detectors, and sensors... When I get up at 8AM my batteries are reading 11.9-12.1VDC before I go into re-charge mode... I make it just fine with the three Interstate 85AH batteries in parallel (255AHs) setup. That is a good average 17-20AMPs (250-300Watts at 12.5vdc) draw for around three hours and then practically nothing for the remaining 8 hours. All of this would go out the window big time if we had to use the furnace. That's when I drag out the Mr Buddy heater...
1150ap
canada
Posted: 08/22/12 05:56am Link  |  Quote  |  Print  |  Notify Moderator
If your running your fridge on propane it still requires 12v power to run the control board.
2010 Jayco 17z
2008 GMC Sierra
