RV.Net Open Roads Forum: Travel Trailers: trailor rocks when set up
 > trailor rocks when set up
srabak311
nebraska
Posted: 08/21/12 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Keystone 2011 Outback 298RE that rocks when we have it completely set up. When you start up the steps or be it in the trailor, it rocks from side to side. Done understand what I am doing wrong. Any suggestions
maskins
Goldston, NC
Posted: 08/21/12 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
make sure all the stabilizers are down all the way. I have noticed on my camper that after I put them down, later one of the jacks will be raised off the ground just a little. I don't know if I just do not put them down all they way, somebody in the campground is messing with me, or something else.
2005 Chevy 2500HD
2008 Sunset Trail ST28BH
srabak311
nebraska
Posted: 08/21/12 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have all them down on tight and have tried taking the jack pressure completley off and tied with a little pressure and stablizers tightly down. Got me puzzled
keatonb16
New Brunswick Canada
Posted: 08/21/12 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
do you have the wheels chocked tight
2007 flagstaff 208
2010 Rav4 V6
tomman58
Southeast Michigan
Posted: 08/21/12 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
A few??? Does this trailer have a Mor/Ryde or similar suspension system? Do you have scissor jacks or the electric stabilizers??
If you have Mor/Ryde you may want to add 2 more jacks 1 on each side near the tires.
If you have the other jacks or electrics use a piece of wood under each. I like to carry 4x6 x 10" blocks to provide a good surface for the jacks.
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
Happy Camper2003
Upstate South Carolina
Posted: 08/21/12 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Our 5er moved a lot as people moved about inside too. I bought the BAL X Chocks to put between the tires on both sides. It didn't completely take all the movement out, but it sure did make a HUGH improvement. Worth a try.
2003 GMC Sierra 2500HD 4X4 Ext.cab Duramax\Allison
2009 Sabre 31 BHDS
Me, DW, and 17 yr. DS who still loves to camp!
GaryWT
MA
Posted: 08/21/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Short of putting it up on bricks, you are going to have some movement. We have movement but we are not in there too often so no big deal.
ME '63, DW 64, (DS 89, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR
wbwood
Mooresville/Troutman, NC area
Posted: 08/21/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would definitely make sure you are using some wood underneath the scissor jacks if thats what you have. A 6x6 piece of wood about a foot long works good. I've tried using a 2x6, but if you are having to extend the jacks all the way out or pretty much most of the way, then it seems less sturdy. The 6x6, helps take up some of the room. We also have to go back and tighten up one or two after walking in it some. Things settle and move. Once we do the tighten up, thing are good. We also use plastic wheel chocks on each side of the camper. One in front of the front wheel and one in back of the rear wheel. We then use x-chocks between the wheels. It all helps.
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
daddyrvpilot
Yuma
Posted: 08/21/12 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought some ultra fab stabilizers from rv adventure.net. We have not installed them yet but they did come highly recommended.
2011 Keystone Sprinter 5th Wheel
2006 GMC Sierra 2500HD w/8.1L
2 kids (2 1/2 & 4mo), 2 dogs, 1 patient and loving wife.
clearnetedm
Alberta
Posted: 08/21/12 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
Ive been fighting this issue as well. I have the xchocks and use wood under the electric jacks as much as i can, but still the same problem. I tweak the jacks dailey without any improvement. Ive chocked it up to the light weight frame on our ultra light and suspect additional jacks by the tires might help. Im just to cheap and can deal with the wiggle for now.
2008 Ford Expy EL
2012 Rockwood 2601S
