RV.Net Open Roads Forum: Travel Trailers: trailor rocks when set up
 > trailor rocks when set up
goducks10
Keizer OR
Posted: 08/21/12 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
At 35' long I'm thinking you need some stableizers like JT's.http://www.jtrv.com/our_products.html
IMO wheel chocks won't do a whole lot. Your TT is so long that it is wiggling on the stab jacks.
You might also try and put a 3rd stab jack in front of the wheels, that will take some of the bounce out that your getting from the long frame.
mister_d
Southeast, MI - hardly qualified to be a
Posted: 08/21/12 11:24pm Link  |  Quote  |  Print  |  Notify Moderator
I think what you're doing wrong is expecting it to be sturdy like a building.
We have stab jacks, between the tire chocks, wood and plastic blocks all being used and still have just enough shaking to know which kid is getting out of bed on the other end of the trailer when we're laying on our bed in the morning.
I thought about putting in jacks by the tires too but people have said the wiggle is still present.
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
shakyjay
California
Posted: 08/22/12 12:12am Link  |  Quote  |  Print  |  Notify Moderator
It's a trailer and as such you can expect some wiggle. My wife walks very heavy even though she is not that big, so if she walks you feel it. I on the other hand walk a little lighter so not much movement. Like others I do use X-Choks and they do help some but do not eliminate all the movement. I have tried using more blocks under the jacks but really don't feel much if any difference. I can see how adding jacks near the axles would probably help and if it were so bad as to bother me I would try it. If you think about it the tires will have some wiggle to them adding a set of jacks could very well help eliminate it to some degree. Bottom line is that it is a travel trailer so some movement is inevitable.
2007 Rockwood 8315SS
2004 GMC 2500HD Crew Cab Duramax Diesel
1999 Dodge 1500 5.9L Gas
wbwood
Mooresville/Troutman, NC area
Posted: 08/22/12 12:30am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you aren't going to stop all the movement.
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
OhhWell
Posted: 08/22/12 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I got a pair of cheap slide room jacks and use them with a small block of wood on top right in front of the wheels. I put them in after I have the normal stabilizers down and the slide room out so everything is settled pretty much how it will stay since they do not move once set. There will always be some wiggle but they make for a pretty darn solid experience.
Last thing I need are the X wheel chauks for front to back motion.
2008 Keystone Sprinter 299BHSS
2003 Ram 3500 CC DRW 4x4
billyjoeraybob
Midlands of SC
Posted: 08/22/12 07:55am Link  |  Quote  |  Print  |  Notify Moderator
We had the same problem. I recently added two BAL scissor jacks one just in front of the axles and one on the opposite side behind the axles. This all but eliminated the bounce in our trailer. It takes the tires and springs out of the equation. I would highly recommend trying this.
2013 Heartland Sundance 3270RES
2013 Chevy Silverado 3500HD CC 4x4 DRW Allison/Duramax
2009 Chevy Silverado 3500HD 4x4 SRW Allison/Duramax(totaled 1/17/13)
2008 Pilgrim International Cirrus 28CQB(Retired)
1996 Chevy Tahoe 4x4 5.7 factory tow package(Retired)
goducks10
Keizer OR
Posted: 08/22/12 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I made some screw jacks and mounted them in between the axles. They take 90% of the bounce out. I can tell when they are not tightened up.
dlos
raleigh, nc
Posted: 08/22/12 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Couple things. If you are having to extend your stabilizers pretty far they will provide less stability. I carry 6x6x6 square blocks to put under each stab as needed so I don't have to drop them so far. Sometimes I'll even add more under those with levelers and such.
After setting up a couple things can happen that will cause you to have to adjust the stabilizers. Tires can change pressure and people walking and moving in the camper can cause shifts and settling that require further adjustments.
I too have set up and come back later to find a jack not touching the ground! Keep adjusting until you are satisfied. It will never be free of movement.
2010 Nissan Armada Titanium w/BT Mirrors
2010 KZ Spree 240BHS LX
Prodigy 2 Controller
Equal-i-zer Sway Control Hitch
Nights Camped in 2012: 24
OhhWell
Posted: 08/22/12 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I was talking about with the slide room jacks. I guess screw jack is a better description. Sure does work though
wbwood
Posted: 08/22/12 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
What type of camper is that? That's a lot of space between the tires. I have about 6" between mine.
