RV.Net Open Roads Forum: Tow Vehicles: Glow Plug Changeouts
Search only in Tow Vehicles
 > Glow Plug Changeouts
morley
British Columbia
Posted: 08/21/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Since last fall we have had two glow plugs(#1 and #8) changed out in our 2009 Silverado shown in our signature.
The check engine light came on again today and the service rep at our local GM dealership says that glow plug #5 is now suspect. We have less than 31,000 Kms on our vehicle.
Has anyone else had this problem with the 2009 Chevy or is it something unique to us.
Or does anyone have any ideas why this is becoming an almost to regular an occurence?
The glow plugs are being replaced under warranty put we would rather be camping than checking why the check engine light is coming on.
Any ideas?
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
Honda EUi2000
NewsW
US
Posted: 08/21/12 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Glow plugs are suppose to last forever.
The problem arise from excessive heat (are you running tuner? or are you running emissions mod, eg no EGR), or excess voltage / current, or bad controller.
Cummins12V98
on the road
Posted: 08/21/12 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Glow plugs on my 6.2 and 6.5 were always going out, now my daughter drives it so I still am changing glow plugs.
Solution, get a Cummins, no glow plugs.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
mazboy
usa
Posted: 08/21/12 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
on my 2006 had one replaced....it was one that in my diesel forum they said it would go bad.
good luck, sounds like there still is a problem.
morley
British Columbia
Posted: 08/21/12 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
We are running straight stock. Not sure about excess voltage or current.
It is a question I could ask.
Paul Clancy
BC Canada
Posted: 08/22/12 03:07am Link  |  Quote  |  Print  |  Notify Moderator
My 09 duramax has had no gp fail. They are cheap and easy to fix off warranty -but still I see your point of why is this happening. My guess would be there was a bad batch of gp and after these few replacements you won't see another issue - but that's only a guess. I had a bad water pump on mine when new - turns out many others did too - replacement is flawless.
boogie_4wheel
SLC, Utah
Posted: 08/22/12 05:48am Link  |  Quote  |  Print  |  Notify Moderator
'Common-mode failure' means that you still have 5 more glow plugs to replace because they have been through the exact same service as the 3 that have already failed. What sucks is that the dealership hasn't gone ahead and done the other 5 from a customer service standpoint.
The life has been short for your plugs but no cause for concern yet. If you start loosing the new ones in a short time period then I would start digging a little deeper.
They are easy to replace. I've done them on a friend's LBZ and I can't immagine yours to be more difficult.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
camping man
Central Fla.
Posted: 08/22/12 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Gets me wonder why they still use glow plugs? Why not grid heater on top of the intake manifold like Cummins, seems much simpler .
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
Cummins12V98
on the road
Posted: 08/22/12 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Just wait until a tip falls off and gets stuck in the exhaust valve!
CKNEK
White Rock, B.C.
Posted: 08/22/12 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Had one go out on my LBZ at 125Kms. Glow plug was $20.00 from NAPA and took me about 20 mins to change.
I don't know if it's true or not but I read they should be changed sooner rather than later when they fail so you don't have the broken tip problem.
07 GMC CCSB Duramax with a few goodies.
