RV.Net Open Roads Forum: Beginning RVing: generator while driving
 > generator while driving
fixyourdns
Sweet Home OR
Posted: 08/21/12 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Stupid question... This is our first RV and was wondering if it is possible or a bad idea to run the generator while driving?
Thanks in advance.
Rich <
Rich and Sharon Sweet Home OR 1984 Southwind [1st RV]
Note: Due to invalid formatting, all formatting has been ignored.
pianotuna
Regina, SK, Canada
Posted: 08/21/12 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Lots of folks do run the genny while driving. What do you wish to power?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Old-Biscuit
Across the USA
Posted: 08/21/12 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Motorhome, trailer, toyhauler.....what rig do you have and where/how is your generator set up?
Running them is what they are for.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
craig7h
Marion, Iowa
Posted: 08/22/12 04:21am Link  |  Quote  |  Print  |  Notify Moderator
If you have a MH, I would run the gen.. When I had MH I ran mine all the time while driving. I used gen power to run the coach AC units. I found it keep the coach cooler. Also ran the refg on gen power instead of propane.
Craig
06 RAM 3500 diesel power
08 35' Cardinal
fixyourdns
Sweet Home OR
Thanks for the quick reply..
New to the forum and our first RV Motor Home older 1984 southwind. The old girl held her shape 27,300 miles. The generator is factory installed at the back.
Just powering icebox maybe roof top AC... but not sure it that should be done...
Thanks again for the quick response
harold1946
Surprise Arizona
Posted: 08/22/12 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Many of us do it quite often. The dash ac will really struggle to keep whole house cooled. Most gennys will use about 5-8/10 of a gallon per hr.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
RoyB
King George, VA
Posted: 08/22/12 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Having a motorhome with a gen built-in is one thing with everything out-of-sight. With the towed RV trailer the generator is sitting in the back of the truck bed in my case at least. My generator permanently sits in the tail gate corner of the truck bed secured to the inside truck bed and can be totally out-of-site when the tail gate is closed and the folding hard plastic bed covers are closed and locked.
I have done it a couple of times with my OFF-ROAD POPUP when I was carrying a desk-height fridge sitting in the front deck of the POPUP. Worked great keep the fridge with freezer cold. These were relative short 2-3 hour trips to the close-by mountains here. Other times I just run my fridge on electric before the trip and then switch to 12VDC during the trip. Always cold and ready to use when we get to the camp grounds...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
accsys
Green Cove Springs, FL
Posted: 08/22/12 06:06am Link  |  Quote  |  Print  |  Notify Moderator
No problem to run it while going down the road. Just one thing to keep in mind: it gets its fuel from the MH gas tank and to prevent you from running the MH out of gas when using the generator, the gas feed from the tank is usually positioned at about the 1/4 full mark. That means when you get below a 1/4 tank of gas the generator will lose its fuel supply.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 08/22/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I run our's for the roof ac's to work in hot weather, also to run the microwave while we're rolling.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
Matt_Colie
Southeast Michigan
Posted: 08/22/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
An Important Point has been omitted!
If you do not have a CO monitor that is less than 7 years old, go get one. The biggest danger with running the genset (APU) is CO poisoning caused by the different airflow around the moving coach.
We run our APU anytime we need the roof A/C or the microwave even when underway.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
