NCSTATE
North Carolina
I am not new to RVing or to towing a 5th wheel (35'). I am new to making long trips. We typically travel about 4 hours or less from home and can either make the trip on one tank of fuel or know good places to pull in with plenty of room. We are making a long trip in the next month (NC to FL), will be mostly on interstate 95 and am wondering what do most people do when they need to stop for fuel. I have a diesel truck and am wondering if truck stops are the way to go or are they not really set up for RVs? Any insights or suggestions will be greatly appreciated, thank you.
ibycus
virginia
even though fuel prices stink, I goto truck stops because there is always enough room to navigate and I fear getting in a situation where I'm stuck.. just me..
2013 Silverado 3500 DRW Diesel
2007 Puma 28BHS
Superglide 4400
ibycus
virginia
*delete*... duplicate post somehow.
pianotuna
Regina, SK, Canada
Hi,
I use gas buddy to find an appropriate fuel station.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
ArmySFCRet
Moving to Congress, AZ
I have found that planning ahead by using StreetView in Google helps a lot. You can see entrance and exit driveways and station layout as if you were actually on the ground in most cases. Not always accurate as some of the street view shots may be a couple of years old.
'04 Cross Country 35' w/300 Cummins
'05 Sebring CV on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/TWIN H-POWER
5 lbs of BG the Yorkie
Members of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
joemusic3210
Louisiana
ibycus wrote: even though fuel prices stink, I goto truck stops because there is always enough room to navigate and I fear getting in a situation where I'm stuck.. just me..
I'd like to get my hands on the idiot(s)who designed these new stations where the pumps are perpendicular to the road. I guess it's because they can get more pump islands in the same footprint but it's a PITA for anyone towing something.
Bob/Olallawa
Kitsap Co, WA
If time is not a problem, we only drive until the tank gets low. Find a campground, unhook and head to the station with out the trailer. Around 8 hours on the road is plenty for a day. If rushed, start looking for a good in out station at half a tank, lots of them around.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
johnrbd
San Joaquin Valley
ArmySFCRet wrote: I have found that planning ahead by using StreetView in Google helps a lot. You can see entrance and exit driveways and station layout as if you were actually on the ground in most cases. Not always accurate as some of the street view shots may be a couple of years old.
X-2
Just remember to checkout station as you pull in so that you will be facing street when exiting, without have to make turns after fueling.
M GO BLUE
Southgate, MI
Wherever you decide to stop the most important thing IS NOT making sure you can get in BUT MAKING SURE YOU CAN GET BACK OUT...if you can't then move on down the road
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
powderman426
ohio
I never use truck stops as there is always fuel on the ground near the pumps and when you get back in the truck you smell fuel for the next couple of hours. I also feel that if your nervous about getting into or out of a station you are probably pulling larger than what you are capable of handling or need a driving course. So what do you do if you get into narrow city streets or whatever?? If your rig got in there, it will get out you just need to have some training. JMO
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
