RV.Net Open Roads Forum: Short Bed or Long Bed on Tow Vehicle?
Search only in Tow Vehicles
 > Short Bed or Long Bed on Tow Vehicle?
Page of 6
smcrea
California
Posted: 08/22/12 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at getting a new tow vehicle.
I currently have a 28' Travel trailer but sometime in the future we will probably move to a 5th wheel size TBD.
I'm trying to determine if this new tow vehicle should have a short bed or long bed.
I've heard that:
- a Short bed gives problems with extreme turning angles.. ie you can hit the cab!
- However with a long bed reversing a travel trailer into a slot in a campground can be very tricky because of the extra lenghth.
I'd really like to hear some opinions on which is better.. Long bed or short bed..
Thanks,
Steve
keatonb16
New Brunswick Canada
Posted: 08/22/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Short bed for looks and resale. hands down.
you shouldn't hit the cab with new FWs
2007 flagstaff 208
2010 Rav4 V6
korbe
Northern California
Posted: 08/22/12 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I use a slider hitch on my short bed that will keep me from hitting the cab. I like the short box because we prefer to travel and camp in out of the way places, where maneuvering is needed. The long bed with either an extended cab, or crew cab were just too long for my liking - larger turning radius.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
mr. ed
Madison, SD (but usually elsewhere)
Posted: 08/22/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have no problem with my short bed. My fiver has an extended kingpin so I can make sharp turns without hitting the cab. I use a Hijacker hitch with manual slider but have never had to use the slider. I'm glad I have a short bed truck and single rear wheels .
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
MitchF150
Washington, the State
Posted: 08/22/12 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Also fits in standard size garage easier!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
downtheroad
Pacific Northwest
Posted: 08/22/12 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
No way was I going to park our big $$$$ brand new truck out side for all the years I plan to own it...short bed fits in our garage. (just)
Never could understand why folks fill their garages with junk and clutter and are then forced to park a $50,000 truck out side in the weather.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
fordsooperdooty
Posted: 08/22/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure that across the brand lines, a long bed truck will have at least a 10 gallon larger fuel tank..a real plus. And you won't need a slider hitch either. And as an added bonus a longer wheel base = smoother ride.
therink
Rochester
Posted: 08/22/12 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
X2- I have short bed and a slider hitch. I have never needed to use the slider for tight maneuvering. My fiver has recessed and radius front cap corners. Long versus short bed is basically a preference.
If unsure of what size truck to get, I recommend the following :
If the fiver you foresee has the potential of pin weight loaded exceeding 2000 lbs, get a 1 ton and skip the 3/4 ton. If the loaded GVWR of the fiver exceeds 14k, get a DRW. My fiver weighs 12k with pin weight of 2,400lbs and my 1 ton SRW is perfect. I had a 3/4 ton truck previously and was overloading it.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
Kalabin
Alaska
Posted: 08/22/12 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Having a 2500HD 6.5' bed the next truck I have if I go back to pulling trailers will be a long bed. I just don't think the 1.5' of difference is going to impact me all that much. I will take the additional storage and stability of a longer tracking rig.
2008 Chevrolet Silverado 2500HD 6.0, 3.73, Firestone Air Bags, CCSB LTZ
boogie_4wheel
SLC, Utah
Posted: 08/22/12 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
+1 to all above. And the wife can pack more junk in the truck bed in case we need it
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Page of 6
