RV.Net Open Roads Forum: Lifespan Can I expect from a 2500 or 3500 Diesel?
Search only in Tow Vehicles
 > Lifespan Can I expect from a 2500 or 3500 Diesel?
Page of 11
smcrea
California
Posted: 08/29/12 07:48pm Link  |  Print  |  Notify Moderator
I'm quite set on getting a new 3500 6.6L Diesel Chevy.
I was just wondering what kind of reliable life span can I expect from this vehicle when towing?
100K, 200K? I have no idea?
Reliable being the key word here!
Would really like some feedback from Chevy 2500/3500 owners on the reliability and durability of this vehicle
Thanks,
Steve
NewsW
US
Posted: 08/29/12 07:51pm Link  |  Print  |  Notify Moderator
Key word is NEW.
That means model year 2012 or 2013.
If you performed all maintenance strictly by the book, including severe service if warranted.
If you never allowed it near the absolute unavoidable minimum of biodiesel.
If you never misfueled it.
If you kept the software updated.
If you never use a tuner or modded it.
If you kept it stock with factory approved updates only.
I'd say 250,000 miles.
With the first 100,000 miles very trouble free.
The things that will break first are not the motor, but all the other parts in the vehicle.
Emissions gear, such as the DEF, DPF, etc. are likely to be weak spots as soon as their warranty expires.
From 150,000 to 250,000 miles, it will be constantly swatting the little problems as they crop up.
* This post was edited 08/29/12 08:04pm by NewsW *
hammer21661
Eastern Shore MD
Posted: 08/29/12 07:52pm Link  |  Print  |  Notify Moderator
Get a Ram NO UREA up to 3500.
07 Ram 3500 Quad cab DRW Cummins 6.7,6 speed auto, Larime 4x4 long bed (affectionatly known as "Super-awesome-mega-truck")11/17/12
05 Kubota RTV 900.
04 Club Car Precident
2013 fuzion 322 all the bells and whistles.8/25/2012
2000 Yellow Lab mix Dog , Earl
chevor
US/Canada
Posted: 08/29/12 07:59pm Link  |  Print  |  Notify Moderator
Im up over 416,000. Just had injectors replaced at 409k. pull campers about 1/2 the time
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 508,000 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
Skinny Man
North Georgia
Posted: 08/29/12 08:00pm Link  |  Print  |  Notify Moderator
My 03 has around 220,000 on the clock. Water pump and alternator are the only things I have had to replace. Injectors were replaced under warranty. Mine also has a 125 horse power adder on it and has since around 100k.
'03 GMC 2500HD
'12 Jayco 25BHS
Rugrat: Peyton
Labs: Catfish, Katy, CJ
GO DAWGS!!!
bovellois
La Pocatiere Canada
Posted: 08/29/12 08:04pm Link  |  Print  |  Notify Moderator
My Dodge CTD is nearing 200k and the engine has never run so well. I go 600 miles on a tank in summer, with cetane boost. No point changing anything.
Bruno, Carol, Thierry and Julien
Sankei the fox terrier
Starla the Gordon setter
97 Dodge 2500 4x QC diesel
2006 ROO19
NewsW
US
Posted: 08/29/12 08:07pm Link  |  Print  |  Notify Moderator
EPA 2008/ 2010 rules on diesels mandated sharp reduction in particulate emissions.
That means that Diesel Particulate Filters must be used.
Selective Catalytic Reduction (SCR) is used by GM and Ford, Massive EGR by Dodge/Cummings and Navistar. Navistar is on its last legs when that strategy (massive EGR) failed and now have nothing to sell until their SCR engines are ready.
Any diesel vehicle that is pre-2008 is not a good compare because of the new emissions rules.
There are now many more parts to break, many things not known.
Prior experience is basically not a guide until a lot more is known about the durability of the EPA 2010 engines.
Don't for a moment think buying a new 2012 non DEF vehicle (e.g. Dodge) is any better.
They have serious issues with massive EGR and DPF clogging and not lasting anywhere near the claimed life.
Oh... put a tuner / mod / delete emissions on the EPA 2008/10 or later ones, and you basically are completely on your own -- no warranty, nothing.
It is the quickest way to having the vehicle lose a large chunk of its value.
chevor
US/Canada
Posted: 08/29/12 08:17pm Link  |  Print  |  Notify Moderator
I run mine 600+ miles a day. That gives the truck time to clean out all that emmsions junk.
rhagfo
Portland, OR
Posted: 08/29/12 08:18pm Link  |  Print  |  Notify Moderator
Thanks,
Steve
NewsW wrote:
Key word is NEW.
He is asking Diesel not gas!
252K and counting pulls our 11.5K 5er just fine, 20 mpg highway, 11.5 pulling the 5er at 65. I use almost a qt of oil between 7.5K oil changes, need I say more.
I own a 01 Cummins, biggest thing hanging over my head is the Bosch VP44 failing about 1K to replace myself.
Russ
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, DS Power Puck, 260K.
2005 Copper Canyon 293 FWSLS
jerem0621
Sequatchie, TN
Posted: 08/29/12 08:19pm Link  |  Print  |  Notify Moderator
As long as you keep it maintained and repaired.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Page of 11
