RV.Net Open Roads Forum: Class A Motorhomes: Rear View Mirrors
 > Rear View Mirrors
Rwake901
Illinois
Posted: 08/30/12 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I have noticed that the rear view mirrors on a lot of the newer coaches are put on the front of the motorhome instead of on the sides. This way you have to look through the windshield to look at the rear view mirror. This is better because??????????? Looks like that would be hard to get used to...
paulcardoza
Southeastern Massachusetts
Posted: 08/30/12 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Because it keeps you facing more forward, instead of turning your head away from the road ahead.........
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
Mr.Mark
California/Tennessee
Posted: 08/30/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Rwake901, our mirrors are as you describe, geared towards looking out the front windshield. I like having the mirrors viewed from the front because if I pull down my side shade, the mirror is not blocked.
Also, when looking out the front, you can glance at the mirrors without turning your head like you would if you trying to view a side mirror.
Actually, if I wanted, I could adjust my driver's mirror to view out the side window but I like it as is.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
rocmoc
Southern AZ/Mexico
Posted: 08/30/12 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Primary reason was for clearance so the things do get knocked off. Buses were the first because of being used / sold in other countries like Mexico. Many times when we have been down there the mirrors had to be pulled in when passing on narrow streets. The old style ridged can't be and can get tore off. After the buses it just became the standard on bus type wide cabs.
rocmoc n AZ/Mexico
rocmoc n Southern AZ/Mexico
bluwtr49
Green Valley, AZ
Posted: 08/30/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure it's just the newer ones....seems like most of the Class A MH's have them in the front.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
Ivylog
Blairsville, Ga. USA
Posted: 08/30/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Having had both ways, I like them out front. What I did not like about the ones in the side window was the reflections you got off the side window glass that sometimes made it hard to see things in the mirrors. This was often a problem when trying to back up, not so much when going down the road.
If you pay by the foot on a ferry, then I might want the side mounted ones.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
kenbert
Long Island,NY
Posted: 08/30/12 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I heard the mirrors are there because of width of coach. Cannot be more than 104" including mirrors.
Ken
95 Georgie Boy Encounter 37ft 5.9 cummins DP
01 Saturn SW
Ivylog
Posted: 08/30/12 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Safety items are exempt from the width requirements plus my mirrors are 112" to the outside. Not sure my slide toppers and awning are safety items.
Executive
Posted: 08/30/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I'm with Ivylog on this one. I had a Tourmaster and hated the side mirrors because of the glass reflection. The Dynasty and the Exec had/have them out front where they should be. It is very easy to get used to, and it's nice not to have to lean forward and turn your head to see the mirrors.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
jerseyjim
New Jersey
Posted: 08/30/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
All depends what you get used to. Mine are on the side...3-way units and they do just fine. However...they are NOT bendable and do not swivel...unless you hit something (like I did) and the glass shatters. $400 bucks for a new one.
I can see the advantage of mirrors "up front"...but I got what I got.
 > Rear View Mirrors
