RV.Net Open Roads Forum: Travel Trailers: ScrewUp: Repacked Sealed Wheel Bearings
 > ScrewUp: Repacked Sealed Wheel Bearings
Page of 5
PEFred
Roswell, GA
Posted: 09/01/12 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I've got a 2011 Trail Sport 20RD and love it lot. We bought it last year and have made several trips across country. I had the wheel bearings repacked last year, and was getting ready to do it again, when I looked in the Manual and found that the trailer's wheel bearings are sealed and don't need to be repacked---Duh!!. You know--Read the manual first. A little late for me.
Does anyone know whether repacking a sealed wheel bearing destroys the seal and thus takes away the quote from the manual: "The sealed wheel bearings comes from the factory permanently greased for the duration of its life", or do I now have wheel bearings that need to be repacked periodically.
If I now have to repack them periodically now, can anyone tell me the mileage or time frequency.
coolbreeze01
Redding, Ca
Posted: 09/01/12 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Who packed the sealed bearings?
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
byways
anywhere
Posted: 09/01/12 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Sealed bearings are just that--sealed. I'm not sure how the person even repacked them. Most sealed bearings have a seal integral to the inner and outer race. There's no way to get grease in them. I would take it to someone who knows what they're doing and have it checked.
Old-Biscuit
Across the USA
Posted: 09/01/12 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
And that place would be somewhere else then the first place you took it....that place 'ripped you off.......knowingly'.
Got the receipt from that job....take it to shop and ask them 'why they charged you for bearing repack on sealed bearings'
Probably won't get your money refunded but the look and stammering could be priceless.
As for your 'greased' bearings....really do need to inspect or have inspected just to be sure that other shop didn't screw them up.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Padlin
W. Ma.
Posted: 09/01/12 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
You sure they are not EZ-Lube's?
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
B.O. Plenty
Minnesota
Posted: 09/01/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Sealed bearings have a metal seal on both sides of the rollers. If you look at them they will be dry on the outside. There is no way to get grease into them..Something doesn't sound right here.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
SWD
Land of Living Skies
Posted: 09/01/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
B.O.
X2 I thought I was beginning to loose it too! Since when do you pack sealed bearings!!!!!
RCMAN46
NorthWest
Posted: 09/01/12 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Just because the manual has a section on sealed bearings does not mean the OP has sealed bearings. I suspect it was an option on his trailer that he does not have. But if he paid someone to pack his bearings and they are sealed he go ripped off big time.
smkettner
Posted: 09/01/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Pull a wheel and inspect what you have. I suspect that is what the shop did.
675 watts solar
westend
all over
Posted: 09/02/12 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Maybe the owner's manual states that "the hubs have bearings that are sealed" rather than "the hubs have a sealed bearing that doesn't need grease". The only thing that can happen if they are a sealed bearing is that the hub may contain too much grease and that may creep into the interior of the hub where the brake shoes are located. Not likely but the hubs/bakes should be inspected and the bearings set as a periodic service item, anyway.
'03 F-250 4x4 CC
Page of 5
