moparmaga2
My old motorhome would smell like that when the grey tank was not clean. I believe that soapscum or the like would build up in it from the shower and it would smell like rotten eggs.
You would only notice this when the coach was in motion.
A flush with bleach and water would fix the smell.
2009 Safari Cheetah 42' 425 HP Caterpillar
2013 Jeep Wrangler
2008 Yamaha FJR Sport Touring Bike
skipnchar
Topeka or somewhere else
Feel for heat around your batteries and disconnect them IMMEDIATELY if they're hot. Internal short will generate hydrogen sulfide gas and it is explosive.
hram
Cedar Rapids, Iowa
Battery meter says full charge and is operating everything fine. The battery that has acid on top does appear bulged, and I know it did not freeze this year. Perhaps I'll take back to Sams in morning and have them checked. Thanks, Ifigure its the cat converter or batteries
Greg
1989 Holiday Rambler Imperial
XS35' P-30 454
Honda CRV toad with Brake Buddy
Baxter riding co pilot with mom.
KNSMCCL
CO
Looking at the batteries, if theirs liquid on top It's not a good sign.
06 Ford F-350 CC LB SRW V-10 4:30 B&W Companion, Air Bags
02 Wildcat 29RLKS
Denver, CO
rockhillmanor
On the Road
hram wrote: Battery meter says full charge and is operating everything fine. The battery that has acid on top does appear bulged, and I know it did not freeze this year. Perhaps I'll take back to Sams in morning and have them checked. Thanks, Ifigure its the cat converter or batteries
Check what your converter is putting out it can be bad and cooking the battery, BEFORE you put the new battery in. That's what I ultimately found out.....after 3 service calls.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
2inAlabama
Huntsville, AL
I agree with rockhillmanor. If your new batteries are boiling over, I think your converter might be cooking them.
Just DH & DW
Daveinet
il
Isolate it first. Plug it in and check the battery temp after about 15 or 20 minutes. See if the battery is hot. If not check it after another 15 minutes. If it was after you shut off the engine, it could be your alternator or alternator connections. Test both and keep and eye on the battery.
Ultimately if it is not the battery, then could be propane, but propane smells more like a dead animal than a rotten egg. Rotten egg is battery.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
RayChez
Barstow, Ca. USA
Daveinet is right on the money on this one. Be very careful if it is propane, very explosive. But I think it is your battery boiling.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
tempforce
Pacific Wonderland (in the summers)
rotten egg smell is the catalytic converter.
the air fuel ratio is off for the engine… so the converter is having to work harder to clean up the exhaust.. the same smell can be observed after a full power run, like pulling a hill or a speedy onramp merge..
a bad tank of gas or old gasoline will also cause the converter to smell excessively.
if after using up the current tank of gas and refilling with a different brand.. if the problem continues, have your engine serviced/repaired. as the converter will get very hot while being used this way…and your engine performance and mileage will be below normal..
somewhere in the texas 'lost pines'
'83' Ford Ranger with a 2.2 Diesel, little smoke
in the workshop:
'56' F100 truck
and looking for a 60's trailer …
WMMitchell81554
Elverson, PA
HRAM, I just finshed replacing my engine starting batteries for this very problem. I no longer have the smell. Two of the batteries had failed, the remaining two were starting the engine. I noticed a big difference in the cranking speed with the four new batteries. Hope this helps
50ft Kingsley Coach Custom, towing GMC Crew Cab
