balfre1946
travelling
Driving today with ABS signal came on then went off again when we used the "drake break" going down a hill. Our manual is of no use. The ABS signal is now off. Any thoughts, we are between Yellowstone and Death Valley on 395?
MountainAir05
New Mexico
if it is a Ford chassis then you have a sensor on the pumpkin drivers side facing foward that could cause this. The other thing is a wheel sensors that is could be dirty. They can be cleaned, If you have a code reader you will know for sure, If not AutoZone and others can read it for you.
balfre1946
travelling
We have a Chevy Workhorse
rgatijnet1
Probably heat related. If it went out, the sensor is OK. A fried sensor will usually cause a steady ABS warning and you will lose the ABS function of your brakes. The brakes will still operate as normal but no ABS in an emergency stop.
wilanddij
CA Desert
Have you had the Bosch caliper recall (51101-C) done?
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
cooper841
Maryland
Just replace the ABS sensor.Hoping you had the brake recall done.Replace mines a yr ago just before the recall work was done.Also check your seal for leaks if they are oiled bath.
Dana & Julie Cooper
Kozy & Pierre
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
balfre1946
travelling
The former owner said the brake mod was done and we are driving in the desert so heat may be the problem, it has not reappeared.
bsinmich
Holland, MI
Have you flushed the brake fluid in the past 2 years? Regardless of Ford or Chevy this is something that should be done regularly. Brake fluid will absorb moisture and that will reduce the braking ability of the system. By keeping the moisture out of the system you also greatly reduce the chance of rust or orrosion on internal brake parts.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
