RV.Net Open Roads Forum: Tow Vehicles: Tundra 290,000 lbs over GCVWR
Search only in Tow Vehicles
 > Tundra 290,000 lbs over GCVWR
jbardram
Long Island, NY
Posted: 09/12/12 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Didnt see this posted anywhere yet.
Tundra to tow Endeavour
If this is legit, it makes me wonder why NASA would allow such a PR stunt
09 Chevy 2500hd 3.73 6.0 CC
05 Wildwood 27' TT
kaydeejay
SE Michigan, USA
Posted: 09/12/12 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
For a quarter of a mile!
Wonder what's towing the shuttle the other 11 3/4 miles!!
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Ron3rd
Upland, CA USA
Posted: 09/12/12 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of trucks could do that on a flat tow. Remember the strongman guy that pulled a 747 with a rope?
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Ron3rd
Upland, CA USA
Posted: 09/12/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Good question, but I bet it's something BIG as the 300,000 lb Shuttle will be towed on city roads to it's final resting place. The 1/4 mile tow is a publicity stunt but the real tow will be done by something that can control that much weight. Not only do you have to pull the Shuttle, you've gotta be able to stop it too.
blt2ski
Kirkland, Wa
Posted: 09/12/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I could pull that with my bobcat at what would probably be the speeds that thing would go! You only need about 30HP to move that load 2-3 miles and hour! Really thing a 300+HP rig properly geared is going to have an issue moving it! stopping is another story, but even then on a level. probably doable!
I seem to recall VW moving a 747 or equal plane a while back!
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
45Ricochet
North Idaho
Posted: 09/12/12 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Ha I pull the moon closer to earth when needed also.
NASA needed my advertising dollars I was told
Didn't you see the Nissan ad with the 747 nose gear landing in its bed. Great ad, but unlikely at best. The nose gear is in the neighborhood of 10 TONS which would flatten any pickup that could make it up to stall speed(Vso) of roughly 140 knots.
Even a new 6.7 PSD would de-fuel in the 2 digit range I believe.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
fla-gypsy
North Florida
Posted: 09/12/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Toyota will try any gimmick to try and sell some of them.
skipnchar
Topeka or somewhere else
If YOU or anyone else did that and broke anything on the truck the warranty would not be honored. That's all GCVWR is, a warranty issue. I assume Toyota owned the truck and they didn't CARE about the warranty.
JPEC
Cambridge, ON
Posted: 09/13/12 02:40am Link  |  Quote  |  Print  |  Notify Moderator
Isn't it obvious..?????
An F150 Ecoboost of course....
I had to.,... that's a great selling gimmick, hell I'd buy one.
Jamie & Paula
275BH Dutchmen Sport
2012 F150 XLT, Max Tow, Ecoboost
gmcsmoke
Butler
Posted: 09/13/12 04:53am Link  |  Quote  |  Print  |  Notify Moderator
in before this goes full retard
