RV.Net Open Roads Forum: Travel Trailers: heater again!!!
 > heater again!!!
kennyd63
Minooka, Illinois
Posted: 09/13/12 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Good Morning-
It is possible that the heater in my T.T. will only work if its plug into a 30amp?
Thanks in advance....
2005 National Sea Breeze LX 8321
2010 Forest River Salem 403FB-Destination Trailer
2009 F150 4X4 Crew Cab
2006 HD Heritage Softtail
1999 Sweetwater Challenger 30hp (Pontoon)
SWD
Land of Living Skies
Posted: 09/13/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
No it should be able to function in 12v mode as well.
JJBIRISH
Butler, PA, USA
Yes it is possible it has a AC furnace in it…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
pianotuna
Regina, SK, Canada
Posted: 09/13/12 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
It would be unusual. What make and model is the furnace?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
skipnchar
Topeka or somewhere else
Posted: 09/13/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
What you suggest is possible IF your battery is dead or if the fuse protecting the battery is blown. The thermostat and the fan motor run off of 12 volt power as does the spark ignighter and with no 12 volt power they will not work. That power can come from a fully charged battery or from the converter/charger and of course the converter only works when plugged into 120 volt AC power. It has to be one of the two.
JJBIRISH
Butler, PA, USA
Posted: 09/13/12 08:02am Link  |  Quote  |  Print  |  Notify Moderator
It could be a battery problem and running off the converter when plugged in,
or it could be a AC furnace and not 12v at all…
According to his signature he has a destination trailer…
joelc
Milford, PA
Posted: 09/13/12 08:43am Link  |  Quote  |  Print  |  Notify Moderator
If your furnace is designed for 120V and 12V it should work on 12V as long as you have good power running to it. Check your battery and the 12V connections at the furnace. With a good battery bank it should last a night or two, depending on how it would cycle to keep you warm.
GpaVader
Brooklyn Park, MN
Posted: 09/13/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Something else to think about. I am big proponent of using electric heat to supplement the furnace. This allows you to cut or reduce our LP use and still keep the trailer nice and warm. In the spring as places like WalMart, Kmart, Target, etc... start to clearence their little space heaters you can pickup a nice one for less than $10. It's also real hand to have just in case you run out of LP
'13 Toyota Tundra 5.7L
'12 Syline Koala 24RBK
wbwood
Mooresville/Troutman, NC area
Posted: 09/13/12 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a furnace or a/c with a heat strip ?
Brian
RVing Illustrated
2013 Thor Chateau 31L
 > heater again!!!
