RV.Net Open Roads Forum: Fifth-Wheels: Main Slide Adjustment
 > Main Slide Adjustment
gtmcx2
PA
Posted: 09/27/12 02:08pm Link  |  Print  |  Notify Moderator
2004 Keystone Challenger 38' 5th Wheel with bedroom, desk, and sofa-dinette slides.
Hoping someone can link me to instructions on adjusting the living room sofa - dinette slideout. When fully open there is a gap of approx in the upper right top and side. When closed all is fine.
This happens to be the only slide I can easily access the underneath rails etc.
bbeezzz
Edmonton
Posted: 09/27/12 05:14pm Link  |  Print  |  Notify Moderator
We had a similar problem on our 2008 Challenger, however there was a gap at both ends and around the top. While in Moab, a strong wind blew against the slide, rocked it and in blew dust,leaves and twigs. When the wind died down, I checked the slide, and you could push at the top of the slide and the entire slide would rock back and forth. It was sealed at the bottom on each end, got progressively looser as you felt up between the slide seal and fiver wall and loose all around the top. In other words, I could get my finger in between the seal and wall.
On return from our trip, I took the unit to our trusted service department who advised the slide was in tolerance and did not need adjustment. Me not happy.
I got out the manual and began to check how the adjustments worked while crawling under the fiver.
Underneath the slide you will see an adjustment bolt that will allow you to raise or lower each end of the slide. There should be two lock down bolts which holds everything in place. I dropped our slide about a 1/2" on each end and now the slide is sealed tight all around. I did the first adjustments 1/4" and there was still a gap. I was satisfied with the 1/2" adjustment.
I also adjusted the slide to seal better when in the closed position. When the slide was opened, there was 1/2 an inch difference between the front and rear of the slide out as measured from the 5th wheel side wall. There is also an adjustment for this variance.
Be aware that all bolts and nuts will be well rusted and will take some lube and effort to adjust.
The Lippert manual supplies information on how to make adjustments for the slide.
http://lci1.com/images/Flyers/Owners_Manuals/slides/om-hydraulic-slide-out-web.pdf
Veebyes
Posted: 09/27/12 05:46pm Link  |  Print  |  Notify Moderator
With the online instructions & eyeballing the nuts & bolts that make it all work the slides are are deceptively ingeneously simple.
Don' forget to slacken the set bolts before messing with the adjustors.
2007 Alpenlite 34RLR
