RV.Net Open Roads Forum: Fifth-Wheels: Power Converter question
 > Power Converter question
klawklr650
Louisana
Posted: 10/08/12 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
A week ago I returned from a two week trip away from the fw. When I returned I found the battery sevice panel in my '08 Keystone Challenger to read "F" and the 12v lights were all very dim. Throughout the week the readings have been all over the map, from "F" to "C". So far today it is reading fully "C" charged.
Prior to the two week trip I'd noticed the 12v lights dimming at times then suddenly getting bright. I've checked the battery and it measures above 12 volts. Water level was good but it was time to add some for normal servicing (this battey is new as the fw was purchased in May). I've checked the connection at the battery and found no corrosion. The converter is a WFCO 9855 and my power dist panel is a WFCO 8930/50. I'm thinking I may have a bad converter. This fw was used as a pipeline residence in its former life. Now it's my residence so I am using all it can give me. As I am a new owner in this RV world, and at times drinking thru a firehose, does it sound as if I'm on the right track?
ken
Boatycall
Tacoma, WA
Posted: 10/08/12 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, sounds like a bad converter. Easy to check a couple different ways -
Watch it with a volt meter, watch for variations in voltage.
-or-
Unhook it, plug a plain old 12v battery charger on your batteries, and if everything acts normal, yup, converter is bad.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
Old-Biscuit
Across the USA
Posted: 10/08/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Check converter DC output when plugged into AC shore power......should be 13.6V DC
If lower, converter is not putting out enough to charge battery and supplement battery draw for DC system.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
smkettner
Posted: 10/08/12 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you measure voltage right on the red and white 12v wires from the converter you can confirm it has failed. Just as easy to remove and bench test. You should see a very steady 13.6 volts. Best to also test with a small load on it.
Easy swap http://www.bestconverter.com/9800-Series-_c_62.html
675 watts solar
klawklr650
Louisana
Posted: 10/08/12 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
WOW!! I didn't expect a response that fast. I did measure 13.6 at the battery cable with the battery disconnected a couple days ago. However, I haven't put a meter on it since and not when I was experiencing the dim light/low service panel reading. I will do that and see what it gives me. As I understand the way things "should" be, the lights should always be normal brightness unless I'm running solely on battery and it is indeed running down. Do I have a good grasp on the normal ops?
ken
Old-Biscuit
Across the USA
Posted: 10/08/12 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
ken
Yep.......
when on battery only....lights etc. will dim as battery voltage drops due to not being recharged. (Fridge will stop working on propane due to low DC voltage...used for controls. Furnace will quit....uses DC to run fan/gas valve/controls. Water heater will quit....uses DC for gas valve/controls)
klawklr650
Louisana
Posted: 10/08/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
ken
Yep.......
Thanks, I'll be watching and measuring throughout this week to see if I can validate my suspicions. If a replacement is required is a WFCO unit a good choice or should I look at offerings from Progressive?
ken
rhingst
Livingston, Texas USA
Posted: 10/08/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
The Progressive converters are real good as they have the Charge Wizard which doe not charge at full rate 24/7 as others do. It periodically boosts the charge up to maintain the charge level of your battery. With one of them you will have to add very little water to your battery/batteries. I checked mine several weeks ago after not checking them for months and only had to add about a teaspoon to 2 of the cells in 2 batteries.
2008 Ford F350 Lariat Crew Cab Powerstroke SRW
2007 Hitchhiker Discover America 339RSB
Old-Biscuit
Across the USA
Posted: 10/08/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Great place to get converters
overthehillbill
Patterson, Ca.
Posted: 10/09/12 06:33am Link  |  Quote  |  Print  |  Notify Moderator
X-2 on the Progressive Dynamics 9200 with charge wizard. If yours is a WFCO it's either bad or will be soon.
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
